Hypex Ncore - Page 495 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Closed Thread
Old 17th August 2012, 02:13 PM   #4941
Julf is offline Julf  Europe
Originally Posted by 3lviz View Post
I think better solution is to put a proper on/off switch to back of the amp, so the "retarded" can't reach it .
That's where I put it
But - I don't use it for the normal turning on/off of the amps, I prefer to use the standby feature.
Old 17th August 2012, 02:23 PM   #4942
Originally Posted by RockLeeEV View Post
Is a single SMPS600 enough for a pair of NC400s? I guess I just don't want compromised dynamics, especially since my speakers are only around 84db/w/m hanging around 4 ohm.
I believe that Bruno said in a previous post that there was little or no benefit to using two SMPS600s. You could do a search to find his exact words.
Michael
Old 17th August 2012, 02:39 PM   #4943
Some have claimed that tests showed that having one smps600 per ncore was audible better than having two ncores sharing one smps600.
obviously havenīt tested this myself -yet
Old 17th August 2012, 02:44 PM   #4944
Actual double-blind listening tests?
Old 17th August 2012, 02:48 PM   #4945
Regnad is offline Regnad  United States
Checking again for any experiences with bridged NC400s??
Sound, pros/cons...
Thanks!
Old 17th August 2012, 03:15 PM   #4946
It couldn`t possibly be double blind, else we wouldn`t know which was which.
Old 18th August 2012, 11:32 AM   #4947
I believe they were listening, but I canīt recall their test setup.
Since nobody seems to have conducted double-blind listening tests with approved double-blind peer reviewed results under current EE and AE standards, I think thats what we have to go with for now.
Julf, I believe it would be of great value to the community if you were to conduct such a test yourself -especially with thorough, precise and detailed test-condition documentation. Iīm sure there are some scientific journals with double-blind review processes where you can try to publish the results
Old 18th August 2012, 11:42 AM   #4948
Cheers - I don't feel any need or inclination to do that testing, as I am personally more than happy with the sound of my nc400's sharing one smps per pair, and as I anyway tend to believe the opinion of the designer of the amps more than somebody's statement that "some have claimed that tests showed" something...
Old 18th August 2012, 11:55 AM   #4949
As stated, the best way to do that is to either use the SMPS standby line to switch the power supply to standby, or nAMPON to put the amp(s) into standby.
Dear Julf, I understand how to put the Ncore amp module into standby but didn't quite get how you do this with the SMPS power supply. And is it advisable to connect both to a standby switch or only one of the two, and if the later which one is better?
Old 18th August 2012, 12:11 PM   #4950
On the SMPS600, pin 1 on J1 is "SMPS Standby" - applying a voltage between 3.3 and 12 V to that pin will put the SMPS into standby mode - and the transition will be a "soft" shutdown/startup.
Well, using the SMPS Standby turns the power supply into standby too, not just the amps, so it is the preferable solution, but requires a separate voltage to be available to drive the standby pin. No problem fro me, as my preamp/DAC can provide the control voltage, but slightly more complicated for a stand-alone amp, where just using amp standby might be the simpler solution.
Closed Thread
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
Copyright Đ1999-2017 diyAudio
