Hypex Ncore
Hypex Ncore
Closed Thread
Old 10th August 2012, 08:35 PM   #4911
sek is offline sek  Germany
sek's Avatar
Anand's build (working link).
Old 12th August 2012, 02:00 AM   #4912
watchthewaves is offline watchthewaves
Default Possible grounding issue?
Wondering if anyone has, any suggestions here:
I have 3 NC400 and 3 SMPS600 built with triggers in 3 monoblock units.
Source is a Denon AVR-3312. So input is RCA to XLR on the NC400. I was going to wire the XLR cable as suggested in the manual, with the sleeve of the RCA connected to pins 1 and 3 of the XLR. But I note the manual says assuming that the RCA sleeve on the source is bonded to the chasis. The Denon AVR power cord is a 2-pin connection only, so I think the RCA sleeve may not be connected to the Denon chasis.
With the above XLR cable, my home circuit breaker trips. When I disconnect the XLR cable, amp stays on but I feel a tingling at the connectors behind the amp.
Thinking that the Denon RCA might not be connected to its chasis and so causing the trip, I floated the XLR cable pin 1 (ie, disconnected the interconnect wire that was connected to pin 1). The trigger ground (from the 3.5mm input) and J9:4 are grounded to chasis. Also decided to ground the IEC to chasis.
Why is it that this trips my home circuit breaker (only power cord connected, XLR cable not connected)? IEC ground cannot be connect to chasis?
Funny thing is in another house, this doesn't trip the circuit breaker.
Thanks for reading and advising.
Old 12th August 2012, 09:03 AM   #4913
Forgot to mention that the other house is on a 2-phase power supply, whilst mine is on a 3-phase power supply. Is that why it trips at my house and not at the other house?
Old 12th August 2012, 09:22 AM   #4914
Julf is offline Julf  Europe
European or US 3-phase? 3-wire or 4-wire? Any idea how your (2-phase) power outlets are wired into the 3-phase feeds?
Old 12th August 2012, 03:03 PM   #4915
Not US. 230V. I think its 4 wire. Into the house, its split up in 3 separate circuits, so it is unbalanced. Tested and found the potential difference between the ground and neutral is about 2 to 4V.
Did some more poking around, might have found the problem. Have a 2-colour LED connected to show standby and active mode. When the circuit for the red standby light is deactivated, the amp doesn't trip the circuit board anymore. Will troubleshoot this now. Thinking of putting in a small transformer to isolate this standby/active LED indicator circuit from the main circuit.
Old 13th August 2012, 11:40 AM   #4916
ChrisPa is offline ChrisPa  United Kingdom
ChrisPa's Avatar
<snip>
<snip>
Not clear from this what your trigger circuit is and how it's connected
As you seem to have discovered in your later post
- disconnect all additional circuitry other than the ncore and smps and then see what happens
- debug the ncore and smps wiring on their own
- then try examining any additional circuitry you're using
Old 14th August 2012, 08:28 PM   #4917
sonnenwender is offline sonnenwender
Default Great Sound, but running hot
I finished building my Ncore amps yesterday night and my first listening impressions are very good. Tremendous clarity, but without digital edginess. Many Ncore owners reported about the amazing bass control. Actually it seemed to me that the bass was going down much deeper than with my Musical Fidelity X-150 and it was actually much more refined and yes, controlled, too. But what I enjoy most is the amount of nuances the amps give to natural instruments. There seems to be more color in the decays and more personality to the individual instruments.
The only thing that worries me is the heat these tiny little amps pick up. They get much hotter than I actually expected, although I listen at really moderate levels. I left them turned on during the day presuming that with the dedicated power supply they'd automatically turn to standby mode. Maybe that didn't happen and that's the problem? Any advice on the heat issue would be welcome.
For the rest: whoever wants to come and listen to these amps in or around Berlin, Germany, is welcome to do so
Old 14th August 2012, 09:06 PM   #4918
nycavsr2000 is offline nycavsr2000  United States
nycavsr2000's Avatar
Hypex Ncore
Sonnenwender,
Depending on how large your chassis is, heat really shouldn't be a significant problem. If you look at my build above (post#4911), you will see that I designed in vent holes on the top chassis. My entire chassis is very small about 215mm x 70mm x 228mm. The chassis only gets warm even when playing for several hours and I have the unit on 'standby' all the time except for listening. I just engage or disengage the AmpOn wire from ground to switch from 'standby' to play. I do know that the unit doesn't 'automatically' switch from standby mode. I have to manually switch it!
All the best, and Enjoy!
Anand.
Old 14th August 2012, 10:11 PM   #4919
mjock3 is offline mjock3  United States
I have the same size enclosure as Anand. Difference being I have no venting. I have been Play mine for 6 hours now and the cover is 90 Degrees F. For an amp this seems very cool to me.
Old 15th August 2012, 07:29 AM   #4920
Originally Posted by nycavsr2000 View Post
Sonnenwender,
Anand.
Dear Anand, which one exactly is the AmpOn wire? I guess I will have to incorporate a switch to disconnect the amp from power when I am away. Might also be a problem of the cases. I bought the dedicated cases from Siliconray with the engraved Ncore logo. They look very nice, but they are completely closed without venting holes. Anybody else out there who used those cases and has heat issues?
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
