Hypex Ncore
Hypex Ncore
Closed Thread
Old 28th July 2012, 09:49 PM   #4881
Studley is offline Studley  United Kingdom
Originally Posted by OllBoll View Post
Maybe you have accidently shorted the outputs, then the amp should click if I remember correctly.
Not that because it works fine when I connect it direct to my source
Old 29th July 2012, 04:00 PM   #4882
DavidT is offline DavidT  United States
Hello Studley,
Sounds like a frustrating issue. Input transformers can resonate 10 dB (or so) at around 40 kHz to 80 kHz. This may cause instability issues or perhaps input overload with a leaky DAC. At the least, resonance can give you a couple dB's of lift at 20 kHz. That lift might sound irritating...
You can properly damp the resonance with an RC Zobel using component values recommended by the manufacturer.
For reference, see pages 370 and 371 of DS's "Small Signal Audio Design" for his discussion of circuits and FR graphs of this issue. He shows a Zobel of 3K3 ohm in series with 4n3 across the output of a Sowter 3276.
Jensen Transformers, accompanied by their recommended compensation circuits, also work well IME.
Apologies, if you have performed this compensation already.
HTH,
David
Old 30th July 2012, 07:04 AM   #4883
Julf is offline Julf  Europe
Originally Posted by Studley View Post
Update: my preamp only has RCA outputs so I am using Sowter transformers to convert the signal to balanced.
Have you tried just using a RCA-to-XLR cable (wired according to the hypex data sheet) without the transformer?
Old 31st July 2012, 03:11 AM   #4884
redjr is offline redjr  United States
Is the NC400 module stereo or single channel? I cannot find this info on their product spec page.
redjr
Old 31st July 2012, 03:23 AM   #4885
cab is offline cab
mono. you need 2 for stereo.....
Old 31st July 2012, 01:45 PM   #4886
Oh great. My project just doubled in cost!
redjr
Old 31st July 2012, 01:47 PM   #4887
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Hypex Ncore
or listen in mono
Old 31st July 2012, 03:15 PM   #4888
Question: Is the new NCore technology proprietary to Hypex, or is this a new Class D industry designation available to other vendors? I'm particularly interested in how this (NCore) technology compares to the B&O ICEPower Class D amp modules.
redjr
Old 31st July 2012, 03:29 PM   #4889
3lviz is offline 3lviz  Finland
The nCore technology is proprietary to Hypex (similar to how ICEpower is to B&O), but there are two versions of the modules, one exclusively aimed for DIY community and one aimed for commercial markets and brands (similar to how ICEpower modules are).
Old 31st July 2012, 03:54 PM   #4890
jtwrace is offline jtwrace  United States
jtwrace's Avatar
Just get 2x NC400 and one SMPS600 to start then add the second SMPS600 when funds allow.
"Science is not a democracy"- Earl Geddes, Ph.D.
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
