Hypex Ncore
Hypex Ncore
Closed Thread
Old 24th June 2012, 03:14 PM   #4561
OllBoll is offline OllBoll  Sweden
Hello all again... I now have a more technical review of the NCore vs the Firstwatt F2J on one of my speaker drivers. The driver is currently mounted in a ported box and is specced at 90 db efficiency. The db level I have no exact number on, but was not super-quiet and not ear shatteringly loud, so don't take the exact numbers as absolute truths
First up the NCore:
Hypex Ncore-ncore-png
Next up the F2J EDIT: In my F2J I skipped the parallell resistors so output impedance should be about 700.
Hypex Ncore-f2j-png
Keep in mind that the F2J is a current source, and the response difference might mostly be due to that. But whatever the reason the measurements for me speak for themselves, I will in my future speaker probably use my NCores for the bass and midbass and then use F2Js for mids and upwards.
So Bruno... I know you said Hypex wouldn't produce a current source NCore but what about after you have delivered the DLCP... pretty please?
Old 24th June 2012, 03:38 PM   #4562
pieter t is offline pieter t  Netherlands
Main difference seems to be in odd (3rd and 5th) order distortion, which is normally most audible.
I guess that the F2J sounds a bit nicer in mid and treble, maybe introducing less listening fatigue.
Old 24th June 2012, 06:54 PM   #4563
jtwrace is offline jtwrace  United States
jtwrace's Avatar
Here are some NCores that I built.
"Science is not a democracy"- Earl Geddes, Ph.D.
Old 24th June 2012, 07:01 PM   #4564
Julf is offline Julf  Europe
Oooh! Sexy!
Old 24th June 2012, 07:20 PM   #4565
DavidT is offline DavidT  United States
Follow-up to Post #4554 (Past post of temp data w/ cover off, also see this for measurement parameters)
Method:
Amp at idle for 6 hrs with vented cover installed. Cut power. Remove cord. Remove chassis cover. Check power supply rails @< 24 VDC. Press TC bead against surface with finger using a 0.5 mm thick coated fiberglass cloth until temp reading stabilizes. Record non-corrected data. All data taken within 3 minutes of cover removal.
Note:
The coated fine weave fiberglass cloth reduces errors due to the heat sink effect of the finger, as well as protects it from electrical shock and heat burns!
These data are less accurate than the previous data, because I did not wait as long as previously for temp stabilization. This is a trade-off between errors due to surface cooling and errors due to thermocouple time constant.
All temp measurements were done with the power turned off and the power cord removed. Power supply rails below 24VDC.
Room air: 21.6 C
UCD 400 ( most surfaces too hot to touch > 1 sec)
Output inductor: 54 C
Main electro-cap: 51 C
Blue T-Bar: NM
User heatsink: 53 C
Non HS TO-220 devices: 85 C
NC 400 ( most surfaces too hot to touch > 1 sec)
Output inductor: 55 C
Highest temp of 10 electro caps: 61 C
User heat sink: 42 C
SMPS 600 ( most surfaces too hot to touch > 1 sec)
Main xfmer: NM
Small HS: 49 C
Large HS original: NM
Large HS w/ user CPU style HS added: 50 C
My Conclusions:
This is a stunning amount of power capability in a very small and light weight package! Well done!
Surface temperatures appear normal for reliable modern gear to me, although I prefer about 10 C more thermal margin for even more extended reliability.
The user added CPU HS (e.g. designed for horizontal use) on the SMPS600 large HS brings it's temp down to about the temp of the SMPS600 small HS.
If the SMPS600 large HS raises in temp approximately the same as the small HS with the cover installed, then the original large HS would theoretically measure about,
46.5*(49/36) ~= 63 C
The 85 C measurement on the UCD TO220's bothers me, but hey, my various UCD amplifiers have survived 6 summers just fine...
Regards, DavidT
Old 24th June 2012, 08:57 PM   #4566
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
is that my vectorial logo?
I would've gone for a smaller one but it's not for me to enjoy it
we all love a good ol' stereotype until it's against us
Old 24th June 2012, 09:03 PM   #4567
serengetiplains is offline serengetiplains  Canada
serengetiplains's Avatar
Beautiful casework, JT.
Old 24th June 2012, 09:15 PM   #4568
waltzingbear is offline waltzingbear  United States
waltzingbear's Avatar
Originally Posted by Abraxas336 View Post
Will correct and report back.
Best Regards
Sven
Report?? Still have noises?
Alan
Old 24th June 2012, 09:35 PM   #4569
pos is offline pos  Europe
pos's Avatar
First up the NCore:
Hypex Ncore-f2j-png
Interesting measurements, thanks!
And with the current source you seem to also get a slight boost in the high, probably following a rise of impedance of your driver. The same things goes around 60Hz (probably the resonant frequency of your driver in your box).
And 15dB of 3rd order distortion reduction!
This back ups my own measurements pretty well.
Have you tried the same test with a resistor on the output of the ncore (something like 2x your driver impedance should be enough to get most of the effect distortion/response-wise).
Even with such (or higher) a resistor you would get more power from the ncore than from the 5W of the F2J.
Old 24th June 2012, 09:51 PM   #4570
Yeah, before I tried to convert the NCore into a current sorce long back in this thread I also tried to put a resistor, I used 30 ohms then in front of a 8 ohm speaker. I got the frequency response slightly changed as expected and a reduction in distortion but very slight, not even close to what you got earlier in the thread where you reported 10-15+ db reduction or what I got now.
I could re-make the test with resistor included also and post graphs, and then I might even be ambitious enough to make an SPL reading so the numbers are more real =)
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
Copyright ©1999-2017 diyAudio
