Hypex Ncore
Hypex Ncore
Closed Thread
Old 25th May 2012, 04:44 PM   #4171
jmbulg is offline jmbulg  Belgium
Originally Posted by Juhleren View Post
Any other experiences with heat dissipation from ncore and/or smps600 out there?
My ncores are at most lukewarm (mounted on a thick alu plate), whereas my Ucd400 in a small alu box get rather hot.
Old 25th May 2012, 04:50 PM   #4172
waltzingbear is offline waltzingbear  United States
waltzingbear's Avatar
mine are SMPS and NC400 in a single enclosure made of medium thickness AL. PSU on all the time, no problem with heat dissipation. Ran over night with approx 2/3 power wideband signal (pseudo-random signal train) into 8 ohm load and the enclosure was slightly warm, output inductor was the hottest thing, but that not bad. Nothing too hot to touch and actually quite a bit less.
Most of the dissipation does appear to be from the SMPS.
Alan
Old 25th May 2012, 04:52 PM   #4173
Juhleren is offline Juhleren  Denmark
Thanks, I guess that both are powered by similar SMPS type supplies?
Old 25th May 2012, 04:54 PM   #4174
Mark.Clappers is offline Mark.Clappers  Netherlands
Mark.Clappers's Avatar
Generally true, but all these effects can be minimised by a clever design. Personally I like aluminium better because its easier to work with than steel.
Music is art - Audio is psychoacoustics & engineering
Old 25th May 2012, 04:56 PM   #4175
Alan
Thanks Alan, the SMPS would also be my guess to cause most dissipation at idle.
Old 25th May 2012, 05:01 PM   #4176
yes both with their dedicated hypex SMPS
Old 25th May 2012, 08:13 PM   #4177
Russell Dawkins is offline Russell Dawkins  Canada
The general claim for using alu cases for audio equipment is due to that it is supposed to be non-magnetic and thereby shouldn´t add any induction to circuitry and cables inside and around it. Other good qualities are far better heat conduction than steel and good mechanical stability.
If you are concerned with inductive effects from the proximity of signal carrying conductors, whether wires or circuit board traces, to the case (and I know of one highly respected amp designer, Yves Bernard Andre of YBA, who is concerned about this) then aluminum is as bad as steel, due to the fact that induced emf in it will produce a magnetic field which will then influence your (again, not magnetic) conductors and thus, contaminate the signal.
Here's a demonstration which shows how aluminium can react to magnetism:
Magnet Brakes its own fall - YouTube
Old 25th May 2012, 08:30 PM   #4178
Great input Russel. It appears to be the same effect as when using alu VC former in drivers. They typically induce a lot of mechanical breaking reading as rather low Qms and thus works as a dynamic break to the coil movements.
I´m not sure that the impact will be entirely similar to that of steel, though.
But you are completely right the alu also does influence electrical signals.
Maybe brass is better -also tougher
I also wondered how a ceramic enclosure might work...
Old 25th May 2012, 09:24 PM   #4179
pos is offline pos  Europe
pos's Avatar
I just quickly plugged one module on a wooden board ans it is working fine, but I wonder if the temperature I get is normal: when idle the aluminium plate of the nc400 gets hot after some time. I can still keep my hand on it for as long as I want, but barely: it looks really hot for only 4W.
What is your experience?
Old 25th May 2012, 09:52 PM   #4180
ChrisPa is offline ChrisPa  United Kingdom
ChrisPa's Avatar
buy a 4W low energy lightbulb, stick your hand on it, and compare - don't fuss about it
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
