Hypex Ncore - Page 413 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Closed Thread
Old 22nd May 2012, 12:36 AM   #4121
Originally Posted by noah katz View Post
Right, I forgot about that factor, but it is also true that if the room is increasing bass it is also raising Q.
In a corner it is 9 db. I would like to see which speakers and placement of them for the people who praise the NCORE .
And once again : I think the N Core is a very good amp but as all other Klass D amps the bass is not for me. I like tight bass nevertheless . 0,1 ohm at the output and it is ok.
Old 22nd May 2012, 01:32 AM   #4122
Do you mean that maximum Zout of the amp should be 0,1 Ohms for good bass? Or is this a different parameter? Thanks.
Old 22nd May 2012, 01:43 AM   #4123
put a 0.1 ohm resistor on the output. Problem solved
Old 22nd May 2012, 06:30 AM   #4124
Julf is offline Julf  Europe
I love categorial absolutes like that. But I have to ask - as you have decided class D is not for you, and you knew from the start that nCore is a class D amp, why are you reading and participating in this thread?
Right. In what parallel universe does increasing amp output impedance and decreasing damping factor make bass "tighter"? Maybe you should just try with longer speaker cables? 50 m might give you *really* tight bass....
Old 22nd May 2012, 06:51 AM   #4125
Right. In what parallel universe does increasing amp output impedance and decreasing damping factor make bass "tighter"? Maybe you should just try with longer speaker cables? 50 m might give you *really* tight bass....[/QUOTE]
Actually longer cable runs often improve low end articulation, so your advice might be better than it originally was intended to be
-It of course depends on the cable and the rest of the system for sure.
MIT mimics this effect by building in a bunch of filter slopes which individual sets of electrical parameters imitate different cable lengths´ articulation points...
Old 22nd May 2012, 07:06 AM   #4126
StigErik's Avatar
True - roomgain may flatten the response, but then a flat response is not something that will sound good. Most listeners prefer a response that is sloping downwards 10 dB or more from 20 to 20 kHz.
In my opinion, bass response should be flat anechoic from the speaker.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 22nd May 2012, 07:14 AM   #4127
StigErik's Avatar
Originally Posted by Sam Lord View Post
It took me a while to count them, but your signature line has one pair too many of dipole woofers...
Question, do you bi- or quad-wire? I've always thought independent runs for each driver to be good for parallel drivers. Are all the woofers parallel, or do you run them series-parallel?
And now I wish to discuss the subject of bass, clearly a tender one for you. Isn't it time to increase the LF output of your system?
Jesus, Mary, and Joseph, that's about three SQUARE METERS of diaphragm.
In America, such systems only appear in trucks. The logic of that, however, is a topic for our next appointment.
Hey...are you playing the 1812 Overture now? My house is shaking!
Ch-ch..e..e..rszz
I almost lost count of them woofers myself.
I run four woofers on each NC400, wired in parallell. The resulting impedance is roughly 2 ohms. Wiring is separate for each driver, call it quad-wiring of you want. I use 6mm2 wires, and they are less than a meter long, since the amp is placed inside the woofer H-baffles.
The famous 1812 on Telarc is a killer, even for my system. Being dipole, it simply can't reproduce those 6 Hz cannons. No way. It even struggles with 20 Hz. Yes, I have 3 sq meters of woofer, but subsonic bass with dipoles is almost impossible. That is the truth, sadly. But then the quality of the bass we can get with dipoles is unmatched.
Old 22nd May 2012, 08:04 AM   #4128
Do you use some large vented subs for below 20hz?
Old 22nd May 2012, 08:18 AM   #4129
StigErik's Avatar
No. I have flat response to 20 Hz, and that is good enough.
I did try to use closed box subs with dipoles, but it just didnt sound right. Dipoles and boxed speakers are very hard to integrate seamlessly, as they sound different and their behaviour in the room is very different.
Old 22nd May 2012, 08:32 AM   #4130
I haven't noticed that happening - what would be causing it?
Closed Thread
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
Copyright ©1999-2017 diyAudio
