Hypex Ncore
Hypex Ncore
Closed Thread
Old 20th May 2012, 01:04 PM   #4091
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Hypex Ncore
Originally Posted by pieter t View Post
Could you explain how your "low Q system" is specified (value of system Q; -3dB LF bandwidth)?
Sorry I do not have that anymore. Here is ts for my midrange. Maybe you can imagine how my bass works then.
Old 20th May 2012, 01:09 PM   #4092
pieter t is offline pieter t  Netherlands
Originally Posted by Erlend Sæterdal View Post
Attachment 283300
No I can't; midrange is a bit different from bass
Old 20th May 2012, 01:14 PM   #4093
Hypex Ncore
Originally Posted by Juhleren View Post
My humble guess is that the low out put impedance was implied to maintain a low Q for the system.
It could sound like that you have gone to great lengths to get a low Q on the speaker side of things -only to depend on having some output resistance on the amplifier end. Nothing wrong with that, but a 0,03R coil sounds like an expensive solution if you really don´t want a total system Q that is as low as it provides.
What kind of woofers and enclosure do you have and whats the rest of the filter on the bass section, if I may ask?
I got those coils because of my amplifiers at that time. Earlier it was a DCA cast with 0,5 ohm . That was no good match for my non feedback The End XP . Now I have those coils and with my new amp it is just perfect. What difference do the rest of my filter make in this combination ? It is a 18 db acoustic filter and 12 db eletric. The enclosure is aprox 140 l.
This is to much about my speakers in this tread . Nothing more about them.
Old 20th May 2012, 01:17 PM   #4094
Hypex Ncore
Yes but not much in this case !
Old 20th May 2012, 01:27 PM   #4095
Agree; it does not make any sense to discuss the loudspeaker - amplifier interface when you don't know the actual performance
Old 20th May 2012, 01:39 PM   #4096
Hypex Ncore
If you knew a little about it is enough I think .
Old 20th May 2012, 01:43 PM   #4097
StigErik is offline StigErik  Norway
StigErik's Avatar
Wouldn´t that depend on the reactance of the coil, hence its inductance as you probably know...
If you imply to simply collate what make up the total impedance in terms of assessing the theoretical damping factor of the system (in relation to frequencies), then my guess is that something important is left out.
Have you tried various coils and resistors and heard their effects on a (bass) system?
cheers,
My point exactly. A 3.3 mH coil will have 1 ohm impedance at 50 Hz. Thus the driver will "see" a 1 ohm shunt impedance at 50 Hz.
I haven't crossed over sub's/woofers with a passive network since the 80's, so I really can't comment on your last question.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 20th May 2012, 02:00 PM   #4098
Trevor White is offline Trevor White  Australia
Seems like you have never listened to a low Q system.
How low a Q is it and why would the ncore not be suitable to drive it ?
Old 20th May 2012, 02:07 PM   #4099
He said he doesn't know, so I don't get the point either
Old 20th May 2012, 10:39 PM   #4100
Hypex Ncore
Q is around 0, 28 . Low Q is very tight bass.
Combination with the very tight bass from N Core results in almost no bass .
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
