Hypex Ncore
Hypex Ncore
Closed Thread
Old 19th May 2012, 11:25 PM   #4071
Juhleren is offline Juhleren  Denmark
Originally Posted by Erlend Sæterdal View Post
I just finnished a much better amp. I do not say NCore is a bad amp . From upper midrange and treble it is for sure a very good amp. Maybee for basreflex the bass is ok too but not for my low Q system.
Some 0.22R or a cheaper coil on the woofer might do the trick with the ncore then
Old 19th May 2012, 11:34 PM   #4072
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Hypex Ncore
You are absolutely right . I had to do that trix on my Coldamps. My coils in my speakers is only 0,03 ohm.
Old 20th May 2012, 01:02 AM   #4073
robbbby is offline robbbby  Canada
I've asked a bunch of times now but it seems nobody knows the answer. There are 3 pots on the ncore, the two close to each other adjust the input and output dc voltage offset, what does the 3rd one on the other side of the amp do?
Old 20th May 2012, 01:04 AM   #4074
DSP_Geek is offline DSP_Geek  Canada
That's the smoke generator. Tune for maximum.
Old 20th May 2012, 01:32 AM   #4075
ajst2duk is offline ajst2duk  Australia
Gold!
Old 20th May 2012, 02:14 AM   #4076
Trevor White is offline Trevor White  Australia
A milliohm output impedance should be more than adequate for the job
Old 20th May 2012, 07:03 AM   #4077
troystg is offline troystg  United States
troystg's Avatar
I was told it was the "dead time" adjustment from a Mola Mola employee. How accurate was that answer being translated from German to English, .
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 20th May 2012, 08:57 AM   #4078
StigErik is offline StigErik  Norway
StigErik's Avatar
At DC possibly. But how much at 50 Hz you think?
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 20th May 2012, 09:21 AM   #4079
pos is offline pos  Europe
pos's Avatar
Originally Posted by jmbulg View Post
Had similar problems/ Without warranty here the procedure written up by Ian based on my experience:
My Understanding of Jos's comment.
1. To adjust the DC offset of the input op amp
No input connected
No output connected
nAmpon disabled (disconnected from Gnd or Hi)
Adjust R95 for 0v between NI input and Gnd ( J9, P2 and P4)
This is how I understood it (in practice I measured on the xlr connector (pin2 and pin 1) at the moment as the module was still in its case.
2 To adjust the output DC level.
No input connected
No output connected
nAmpon enabled ( connected to Gnd J9.P4)
Adjust R136 for 0v between output + and output -.
Right
3 To Calibrate the overvoltage
No input connected
No output connected
No DC power connected (No SMPS)
Apply 3.0v to the 5 pin Prog Header for a few seconds
P1 -ve P2 +ve (Pin one is near the red capacitors)
There are no adjustments to be made. ( I don't understand what is going on
inside the electronics, the 3v must be being used to charge a capacitor but
how does it hold its charge when power is removed - pass at the moment)
maybe some flash memory modified to tell the ncore the calibration is done ?
On power being re-established and nAMPON enabled the amp should switch on
right
WHAT DO YOU DO IF THIS DOES NOT WORK ?
try several time the recalibration, if not successful, I think the only way is to send back to hypex
It is strange this tweaking is still necessary:
Originally Posted by Jan-Peter View Post
Originally Posted by pos View Post
If I order now will I get my amp from the wk21 batch?
Do the amps from this batch still require DC tweaking?
If you order now, delivery is within two weeks. There is no DC tweaking necessary.
Maybe it is only true for units from batch wk21 and up?
Old 20th May 2012, 09:24 AM   #4080
jmbulg is offline jmbulg  Belgium
Mine were shipped early april.
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
