Hypex Ncore
Hypex Ncore
Closed Thread
Old 17th May 2012, 10:32 AM   #4031
StigErik is offline StigErik  Norway
StigErik's Avatar
Is it really possible to turn the NC400 into a transconductance amp ? I would expect stability issues, as the switching signal residual at the output would be fed back to the amp's inverting input.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 17th May 2012, 10:35 AM   #4032
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
The level of the switching signal residual will of course be attenuated by the value of the sense resistor (perhaps around 0.22 Ohm?) compared with the impedance of the load at the switching frequency.
Old 17th May 2012, 10:42 AM   #4033
StigErik's Avatar
I'm just waiting for the first guy willing to try this ...
An other question: should not the open loop gain of the "op-amp" (the NC400 in this case) be as high as possible? The NC400 has just 26 dB of gain, while a typical op-amp chip is in the 100 dB territory.
Old 17th May 2012, 10:47 AM   #4034
ChrisPa is offline ChrisPa  United Kingdom
ChrisPa's Avatar
Originally Posted by pos View Post
So how much watt would a NC400 be able to output in a 4/8/16 ohms load with such a feedback loop?
Choose your own Rf and do the maths
ncore is current limited to 24A max (typical) continuous (DC not RMS)
ncore load = Rload + Rf
work out total power avail (note: RMS not peak)
work out proportion of power available to Rload (and not being dissipated in Rf)
Old 17th May 2012, 10:55 AM   #4035
ChrisPa's Avatar
Surely Bruno's already done that for us?
If this were a problem wouldn't it already be a problem with the nc400 as a voltage amp?
Bruno says he already has, and it's in the Grimm LS1
26dB is the closed loop gain - we need to open the loop
Section 6 of the data sheet specifies 56dB (open) loop gain (min) at 20kHz - ie. it's higher than that elsewhere,
but by inference it may be a max of 62 dB at 15kHz
Last edited by ChrisPa; 17th May 2012 at 11:09 AM. Reason: correctly format StigErik's quote
Old 17th May 2012, 10:59 AM   #4036
Ouroboros's Avatar
Because the NC400 doesn't have infinite gain, then the actual output impedance will be lower than you would get in the 'text book' circuit using an ideal op-amp and a current-sense resistor.
It is a simple matter to calculate the Z(out) you will actually get for a gain block with less than infinite gain, or you could easily simulate it with one or other flavour of SPICE.
Old 17th May 2012, 11:02 AM   #4037
Ouroboros's Avatar
How are you intending to open the NC400 normal NFB loop? All this talk about the O/L gain is not relevant otherwise. If you are going to add a simple current-controlled NFB loop around the amp and speaker unit then you need to use the C/L gain of the NC400 for the calculations.
Old 17th May 2012, 11:11 AM   #4038
ChrisPa's Avatar
Exactly - that was a question I was asking back in my original musings
Old 17th May 2012, 11:43 AM   #4039
StigErik's Avatar
Would it make any sense to turn the NC400 with its 26 dB gain into a transconductance amp, that is without making any modifications to the NC400 itself to increase the gain?
In any case we would have to sacrifice balanced input.
Old 17th May 2012, 12:18 PM   #4040
pos is offline pos  Europe
pos's Avatar
So to me that is quite the same as putting a resistor inline with the driver? Will not Rf still be burning much of the outputted power? I don't really understand the practical difference.
in my experiment I was using a 44 ohms resistor inline with a 16 ohms driver (Re, but lets simplify). That gives a total load of 60 ohms, and only ~1/4 of the outputted power going into the driver.
My amp puts 690W into 8 ohms, so should be able to put max 100W into 60 ohms, so around 25W going into the driver itself.
With a 200W/8 ohms ncore the same logic would go down to less than 7W...
I am sure I am missing something here, though
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 06:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
