Hypex Ncore
Hypex Ncore
Closed Thread
Old 30th March 2012, 01:12 PM   #3151
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Hypex Ncore
Default Confusion J 9
Something is wrong no output ! I think the Drawing of the connections on J 9 is wrong.
I use RCA . The red is connected to the hot at the RCA. The white is connected to ground. The Black thin one is not connected to anything.
No output no sound. This Drawing could be better.
Old 30th March 2012, 01:21 PM   #3152
Mark Verhoeven is offline Mark Verhoeven  Netherlands
Did you check this out: http://www.hypex.nl/docs/NC400_datasheet.pdf
Do you have nAMPON connected to ground?
8.3 Control
The amplifier has exactly 1 control line: nAMPON (pin 3 of J9). Pulling nAMPON low enables the
amplifier as soon as all error conditions have been cleared for at least two seconds.
Old 30th March 2012, 01:22 PM   #3153
Julf is offline Julf  Europe
No output no sound.
That is because the black one is nAMPON. It has to be connected to ground to turn on the amp.
I have to say the drawing and the documentation is one of the clearest I have come across. A lot better than the Ikea ones
Old 30th March 2012, 01:32 PM   #3154
Hypex Ncore
Thank you I am a bit stressed for several reasons. I will connect the black to Powersupply ground. Why is it not connected on the board allready ?
Old 30th March 2012, 01:36 PM   #3155
OllBoll is offline OllBoll  Sweden
If I've understood correctly nAMPON is mute functionality which is disabled when connected to ground.
Old 30th March 2012, 01:46 PM   #3156
Hypex Ncore
Ok then a switch would be the right way to do it.
Old 30th March 2012, 02:04 PM   #3157
Hypex Ncore
Still no output .
Old 30th March 2012, 02:07 PM   #3158
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
try signal ground (not earth).
I just skipped the whole standby functionality for the time being and soldered nAMPON to pin 1.
Si fractum non sit, noli id reficere!
Old 30th March 2012, 02:09 PM   #3159
Me too, though I connected pin 1 to earth also... you can't be too careful in my opinion
Old 30th March 2012, 02:16 PM   #3160
Well, I guess that is exactly the point. You can put a switch on it if you want to. Or use it to remotely mute the amps from the preamp. Or whatever. That is the "DYI" part of it.
Closed Thread
Hypex NcoreHide this!Advertise here!
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 07:36 PM
Problem with Hypex Ncore Koifarm Class D 29 13th October 2014 07:32 AM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 11:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 05:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 10:08 PM
