ICEpower 50asx2 modules
Old 3rd January 2012, 01:40 PM   #11
yoke is offline yoke  Croatia
yoke's Avatar
Stokessd - it's a little difficult for me to track your words, mi mind is more like in off state, but I think I understand it.(it's bean a while sin I play with diy stuff )
so;
- I have digital crossover DCX2496 which have balanced outputs
so I don't nead phase inverter, right ?
here is some pictures of 50asx2
and here is the bottom of PCB
there is some jumper for SE i BTL mode, which I have to disorder as I drow in second picture , right ?
Old 3rd January 2012, 03:53 PM   #12
StigErik is offline StigErik  Norway
StigErik's Avatar
I dont think you can rewire a 50ASX2 stereo to become a BTL. The BTL module is missing som parts compared to the stereo module, at least there is only one output choke.
What you can do is to feed them balanced signal from you DCX, connect speaker to both "hot" outputs, and hope for the best. It will work, but if its any good I cant tell.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 3rd January 2012, 03:53 PM   #13
StigErik's Avatar
Originally Posted by StigErik View Post
I dont think you can rewire a 50ASX2 stereo to become a BTL. The BTL module is missing some parts compared to the stereo module, at least there is only one output choke. I know, because I have one BTL module.
Old 3rd January 2012, 05:38 PM   #14
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
If I recall correctly, the missing components on the BTL module were stripped for cost reasons only. You should be able to use a stereo module for BTL without issues (no guarantees though, my memory may be off )
/U.
Old 4th January 2012, 08:02 AM   #15
yoke's Avatar
Yes, am also think, that missing part's a for cost reasons.
will power it in a next day's and see will it burn in flames
Old 7th January 2012, 10:04 PM   #16
yoke's Avatar
Small info,
just got replay from ICEpower that stereo version can't be transfer to BTL mode.
Thay say that they are two diferent versions from factory and modification can't be done.
The info come from icepowerinfo (at) bang-olufsen (dot)dk
Old 18th January 2012, 12:46 PM   #17
evanghelatos is offline evanghelatos  Romania
Default 50asx2
Hello,
I have a ICEpower 50asx2 module, SE edition (2x50W) and I found something interesting concerning the sound. I want to know if this is a problem or a normal behavior?
I connect the IN connector of the module either directly to the laptop output or a audio mixer (Phonic AM220) master output. When I move the balance to L or R, I get more bass on one or the other speaker. If I put the balance to middle position (normal), the sound loose some bass. Is this normal? Do I have to make different connections on input of the module? I think it's a simple analog input with L, R and common ground.
Old 18th January 2012, 01:48 PM   #18
StigErik's Avatar
Maybe you have one of the speakers out of phase? That would explain this.
Old 18th January 2012, 01:53 PM   #19
Kjeldsen is offline Kjeldsen  Denmark
Definately sounds like one speaker is out of phase.
Old 19th January 2012, 12:30 PM   #20
phase_accurate is offline phase_accurate
Agreed !!!!
ICEpower 50asx2 modulesHide this!Advertise here!
Icepower Modules spchu Class D 15 23rd May 2011 10:24 PM
ICEPower modules for sale Alfetta87 Swap Meet 24 10th September 2010 05:14 PM
IcePower modules w/ wiring kit csuflyboy Swap Meet 5 14th November 2009 08:03 PM
Need one ICEpower 200ASC modules thim Swap Meet 1 14th February 2009 03:48 AM
