Go Back   Home > Forums > Amplifiers > Class D
Old 5th June 2011, 10:12 AM   #1
Default Veldyne class D amp consumption?
Hello,
In the near future I'd like to buy a velodyne SPL 800 which has a 1000w classD amp.
Before I want to built a balanced transformer to feed my entire system.
I can't find the consumption of that kind of amplifier to estimate the VA rating of my balanced transformer...
Maybe the fuse rating could give me good indication?
If somebody knows or can estimate it...he'll be welcome!
Thanks a lot: David
Old 5th June 2011, 10:41 AM   #2
Pafi is offline Pafi  Hungary
What for?
Theoretically the power consumption could be 1100 W for a short time, but I never experienced 1000 W power output from SPL800, the in-built limiter limites it earlier.
In real life the average power won't exceed 100 W (otherwise the cabinet would burn out).
Idle power is about 10 W.
If you ask me, the power rating is nonimportant, only DC resistance matters. 1+1...2+2 ohm (primary+secondary) is OK (the lower the better).
Old 5th June 2011, 12:20 PM   #3
What for?
Balanced Power from Equi=Tech
Yes I ask you! The DC resistance you're talking is about the balanced transformer?
I've found on the web an answer from a man wich gives the answer of a Velodyne technician: "Under 'normal' listening conditions in a 'normal' size room, I would estimate the wattage draw to be 100-400 watts. Keep in mind for every 3db increase of volume you double the power required, so going from normal to loud can increase the draw dramatically."
Thanks for your help
Power consumption Zanthus Full Range 10 19th September 2010 12:01 PM
Class D - about current consumption from the supply - a question folks destroyer X Class D 6 18th August 2008 01:57 PM
power consumption tfrei Chip Amps 2 1st December 2007 10:34 PM
Op amp current consumption - dual vs. single speakerguy79 Parts 2 20th March 2007 10:21 PM
Dukane IB3250 ("two-fifty") high current consumption handy Solid State 0 9th August 2004 04:14 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
