diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   mtx 4250d powers on but lights out when sub hooked up (http://www.diyaudio.com/forums/class-d/189906-mtx-4250d-powers-but-lights-out-when-sub-hooked-up.html)
ford06f150 30th May 2011 04:13 AM
amp powers on. led red but when i hook up a sub to any speaker port sub cone sucks down and i get a thump and a hum or buzz. cone stay pulled down and led goes out but as soon as i unhook subs led goes back red. very new to this how do i tell whats output or input transisitors? i see theres is 6. i know 2 for in 2 for out but not sure on other 2 i did find one that did not move my muliti meter so i took it out. saw a youtube video where a guy took out the bad ones and tested it with them out to see if it helped and it fixed it. that way u can see if thats whats doing it and it worked for him. i still get the same with it out. thanks shaun
nigelwright7557 1st June 2011 12:15 AM
The output transistors are the larger ones.
Could be an output transistor(s) gone.
They usually go short S-D or C-E.
ford06f150 1st June 2011 09:49 PM
all transistors same size
i saw that in my other amps but this one they are all the same in size. any one know how to test them with mulimeter. there are 2 next to the speaker outs guessing thats them. thanks shaun
nigelwright7557 1st June 2011 11:58 PM
Originally Posted by ford06f150 (http://www.diyaudio.com/forums/showthread.php?p=2591588#post2591588)
Test them with a multimeter on low ohms setting.
There shouldnt be a short between any two pins.
ford06f150 2nd June 2011 12:37 AM
what should meter read
on one my meter does nothing acts like im not even touching anything no mater witch 2 its on. other it jumps up and drops fast no mater witch ones its on. thanks shaun
Copyright 1999-2017 diyAudio
