Go Back   Home > Forums > Amplifiers > Class D
Old 26th May 2011, 11:32 PM   #1
sled108 is offline sled108  United States
sled108's Avatar
Default TK2050 Phono Trouble
For a while now, but not always, my Sure TK2050 has a Problem with LP's...At first I thought that it was my Tube Phono Stage having a Problem with the Chip Preamp. When the Vol. hits a certain Point, around 11:00 it Oscillates, then the Amp will Cut Out and turn off... So, I ran it right into the TK2050 and used the Phono's Vol. Knobs..Same Thing...Next, I just tried a VSPS into the Pre, and the same thing happened. I have to conclude that it's not a Tube Thing, a Chip Phono Stage thing, or a PreAmp Thing...So what is It? At one time I could use Both of these Phono's up to 1:00 before the Amp would Shut Down in the Regular Way, No Oscillation..
And Also, the Amp will Play at Full Tilt Boogie from the FM Input...Does anyone know why this happens?
Old 26th May 2011, 11:55 PM   #2
teamacc is offline teamacc  Netherlands
Does the pre have a big dc-offset?
Old 27th May 2011, 12:06 AM   #3
sled108's Avatar
No...That was one of first things that I Checked...But just now, the Plot Thickens...I've just ran the Tube Phono into the Marantz 7T's Aux Inputs, and then fed it back into the Chip PreAmp from the Marantz's Headphone Jack....I'm afraid that it will Pop a Woofer now that it's Playing so Strong...No Oscillation now, only 2 Volumes now to deal with... And the TK2050 will get Loud as it ever has....
........I just ran the 7T right into the TK2050...It Sounds Awsome!..
New TK2050 board hifimediy Class D 2094 10th May 2012 12:36 AM
TK2050 and wire CrashHouse Class D 5 12th March 2011 01:22 PM
TK2050 Amp kunalraiker Class D 4 24th November 2010 03:18 PM
Sure TK2050 and Phono Stage vcmarshall Class D 0 30th July 2010 09:22 PM
Having trouble building a power supply for a phono preamp SideA Solid State 1 4th April 2003 06:34 AM
Page generated in 0.07773 seconds (72.01% PHP - 27.99% MySQL) with 10 queries
