Yet another IRS2092 problem
Old 27th May 2011, 06:47 AM   #11
LukeFrog is offline LukeFrog  New Zealand
Hay luka,
Yes you are right, the dead time is currently 105ns, and the inductor is 30uH not 30mH. No sleep makes eyes not work very well.
It is currently switching at around 400-450kHz.
When we first plugged it in and ran it with a 2vp-p signal we were getting about 3vp-p out. so we increased the value of the feedback resistor from 64k gradually up to 330k were we are now getting a 40v p-p signal out.
Old 27th May 2011, 02:52 PM   #12
luka is offline luka  Slovenia
luka's Avatar
reduce the gain of the amp, now you have 100x gain, way too much
It was pointer out to me, and I see it too, that you guys don't know how to set nor calculate the gain of the amp and what input capacitor to use
1. you don't have input resistor, that with resistor in feedback set the gain
2. your input capacitor size would be good for anything but sub application
Here is what you do, increase input capacitor to atlest 1uF, anything up to 10uF will work great too. Add 3.3k resistor after it. Reduce 330k feedback resistor to 120k
that will give you gain of about what, 35 or so
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 27th May 2011, 08:16 PM   #13
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Originally Posted by LukeFrog View Post
Hay luka,
I found my amp got warm (2092+mosfets) when running that fast.
200KHz would give a cooler solution.
PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 27th May 2011, 08:17 PM   #14
luka's Avatar
I run my at 460k
I FEEL SLOVENIA
Old 29th May 2011, 01:56 AM   #15
Thanks everyone for your help! It is now going and sounding pretty good
We added some extra caps over the rails as we were getting a fair bit of bus pumping at the lower frequencies, which has solved that problem.
Interestingly, we can run both sides in half-bridge configuration with no worries, they both perform well and we can see on a scope that they're indeed the inverse of one another. However, when we hook them up in BTL configuration, both chips cease function and toggle their CSD pins.
We can't think of a reason for this as everything works up until we connect the speaker across both outputs.
Any ideas?
Old 29th May 2011, 07:57 PM   #16
Any ideas?
Remember in BTL mode the speakers must be twice the impedance or you will get an over current event.
Old 30th May 2011, 11:07 AM   #17
student_sound is offline student_sound
student_sound's Avatar
Default HI LukeFrog !
I M NEW IN CLASS D ,MY AMP 7 PCB NEAR TO FINISH . CAN I STUDY EXPERIENCE FROM YOU ? CAN I USE IRFB4227 ?
BEST REGARD !
Old 30th May 2011, 08:23 PM   #18
BEST REGARD !
I use a pair of irfb4227 in my design and they work well.
They are a little high on gate capacitance but the 2092 seems to drive them OK.
Old 31st May 2011, 02:59 AM   #19
Talking hi niglelwright !
i bought some irfb4227, irf640 and t_130-2 my power supply is +/- 63v , R gate driver 10 ohms . is it okie ? last time, i test my design in break board it resets when clip like yr .maybe pin ocset or DC protect works not right ,have u fix your amps ?
i hope my amps 7 works good .
philip .
Regard !
Old 31st May 2011, 05:38 AM   #20
Default HI !
MY PCB is ready to make .it can brige or stereo . uv, ov, dc, oc protect but no temp and clip limit, i will make it with lm3080 late , can it work ?
Regard !
We can do it better than that why don't.......
Yet another IRS2092 problemHide this!Advertise here!
IRS2092 with IRFB4227 problem! tantal.lpt Class D 72 22nd June 2017 08:29 PM
Irs2092 luka Class D 50 15th July 2012 01:48 PM
Irs2092 gxhcdba Class D 11 14th December 2009 10:54 AM
IRS2092 help! yudi02 Class D 2 11th October 2009 03:30 AM
Copyright ©1999-2017 diyAudio
