| Class D Switching Power Amplifiers and Power D/A conversion |
Hello audiophile community
![]() I have a board called VMA2015 class D amplifier which is actually two separate mono amplifiers. I want to switch 2.1 speaker system in this. Actually tweeters is no problem just each goes to 1 amp. BUT what should I do with subwoofer ???How can I mix signal at output to direct it to only one speaker? Is it possible just to attach it to + channels of these separate amplifiers? I guess it's a very stupid question? Anyway, thanks for support Last edited by Tinto; 18th May 2011 at 01:24 PM. |
#2 |
Audio Engineer
To answer this question we need a bit more information I am going to rephrase it to see if I understand what you are asking.
You want to run:- 2xtweeters and 1x subwoofer From 2 x VMA2015 You want to mix the bass for the subwoofer so you can use both amplifers for the sub. I do not belive this is possible. If your tweeters have a crossover then you could run 1 tweeter on each amplifer and The subwoofer on one of the amplifers. Most low frequency in music tends to be mono so it will probably sound OK but not audiophile. If you want all the bass from both channels to be directed to one of the amplifers for the subwoofer you will need to design a filtered summing circuit. This is possible but not trivial and for the quality you are likely to achive probably not worth it. Regards, Andrew |
#3 |
You could bridge the amplifiers.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#4 |
Audio Engineer
This design of amplifer is already bridged. Also this would not drive the two tweeters.
Regards, Andrew |
#5 |
Yeah,
I guessed gfiandy is more then cright! but my friend told me that he's seen something like that on the web.... and I followed the catch ![]() Sorry for that and thank you for support!!! |
| Auna ALP404CH two channels drawing exessive current when speaker connected | Mote | Car Audio | 67 | 24th April 2011 06:43 PM |
| Wiring two stereo channels to one sub? | ancorp | Car Audio | 7 | 22nd December 2010 03:54 AM |
| Can I run tweeters off front channels and woofers off the rear channels of a headunit | codyd70 | Car Audio | 0 | 3rd October 2010 06:11 AM |
| bridging channels on stereo reciever | 9am53 | Solid State | 10 | 8th December 2005 03:16 PM |
| Stereo speaker crosstalk cancellation | I_Forgot | Digital Source | 1 | 15th February 2005 11:49 PM |
| Page generated in 0.08986 seconds (71.30% PHP - 28.70% MySQL) with 10 queries |
