Go Back   Home > Forums > Amplifiers > Class D
Old 17th May 2011, 01:20 PM   #1
markusA is offline markusA  Sweden
Default Class-D Discrete vs Chips?
In the traditional amplifier world OP-amps and chips in general are often considered sort of "low end".
Now we're in the Class D forum and the rules have suddenly changed.
Which is better? To use transistors or chips?
When you buy OP-amps and readymade cirquits they are already optimised for performance, is there any reason to use the old school components beside maybe saving a $? I said maybe because the new cirquits aren't so expensive anymore.
Old 17th May 2011, 09:07 PM   #2
nigelwright7557's Avatar
For a first design I would go with a chip solution.
Chips like the irs2092 have deadtime and over current protect built in.
Once you have mastered a chip solution you will be ready for a discrete design.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 17th May 2011, 09:09 PM   #3
I take it discrete cirquits are still king then?
(As long as it's designed the right way)
Old 18th May 2011, 07:13 AM   #4
Hitec is offline Hitec  Finland
Somehow I think IC is always better if specifications for design are good and design is well made. Anyway, I don't have any experience on comparing these two objectively. Some good reasons could be:
  • Tighter layout on substrate. This translates to better EMI properties, smaller parasitic components and shorter transmission lines (digital circuits).
  • Well tested as no one makes on IC before making sure it works
  • Smaller footprint on PCB
  • Ease of use --> may be a downside for a hobbyist
However, it is interesting to make a circuit to work with discrete components.
Old 18th May 2011, 08:33 AM   #5
For very first design IC is the best choice.........once got experienced then you can move to discrete components as your requirements change.
Old 19th May 2011, 10:20 AM   #6
Default chip vs discrete
Hello,
(i'm french)
i'm persuaded than chip is better, shorter lenght...
the discrete make a lot of loss....
oNLY BLIND TEST CAN easily answer to this questtion
bye
Old 19th May 2011, 11:36 AM   #7
marce is offline marce  United Kingdom
High DI/Dt switching etc the technology is better with integrated designs, using discretes and especialy through hole, you are adding parasitic inductance, not good for class D.
discrete opamp class A branet Digital Source 17 25th October 2011 07:04 AM
My discrete class d project nigelwright7557 Class D 24 15th December 2010 10:10 PM
My all discrete prefilter class-D kartino Class D 10 7th August 2006 08:47 AM
My 13x discrete class-D kartino Class D 6 21st November 2005 07:44 AM
recommend discrete Class D rellik Class D 11 3rd November 2005 01:27 AM
Page generated in 0.08683 seconds (68.88% PHP - 31.12% MySQL) with 10 queries
