Go Back   Home > Forums > Amplifiers > Class D
Old 16th May 2011, 05:51 PM   #1
Centvrion's Avatar
Question HELP: Budget sub amp
HELP FOLKS!
I need a pre-soldered kit (or even a car-audio ready-to-use) -possibly class d- amplifier to power my two subwoofers, I will make by myself the (active) low pass filter.
Maximum budget for amp module and PSU=40€ (about 60$), shipping and taxes included.
I have to power a pair of 4ohm 40W ("nominal") 6,5" sub in t-line (tuned at 40Hz), don't know about their efficiency, but I need no more than about 15W (or a bit less) of "undistorded" power.
Can someone give me some advice?
Old 16th May 2011, 06:23 PM   #2
2010 New Model TOPPING TP20 MK2 TA2020 T Amp + Adapter | eBay
Not sure if its going in car or a house, but ebay a ta2020 amp should fit the bill.
MKIII Tripath TA2020 PCB 25watt Class-T amplifier SET | eBay
this guy is running around the forums and is pretty good.
Old 16th May 2011, 06:41 PM   #3
Centvrion's Avatar
Thank you nightanole :-), umm...TA2020...that's what I was looking for!
It's for home use:-)
Is there any cheaper module? (I have to add 25% taxes because in Italy it's pretty difficult to ship with ordinary shipping - it will take between 4 and 6 weeks :-!!!, and express' rarely permit to value the pack as "gift", moreover express costs a bit more)
Is there any other idea in order to have a bit wider choice?
Old 16th May 2011, 07:07 PM   #4
Like i said look for something with the ta2020 chip in it.
Tripath TA2020 Audio Sound Home Amplifier T-AMP+adaptor | eBay
Id try to get one from HLLY if you want name brand china with a case.
If you want alittle cheaper you can try this
MKll Tripath TA2024 fully finished&tested pcb 2x15watt | eBay
Its a ta2024 so its 15 watt x2 instead of 20watt.
Budget Amp fussion101 Car Audio 4 22nd February 2010 04:15 AM
Budget T-amp system sub? wakibaki Subwoofers 21 3rd March 2008 02:30 PM
$300 tube amp budget. Which Amp?? Runco990 Tubes / Valves 32 1st March 2007 11:10 PM
Tube amp on a budget Sal Brisindi Tubes / Valves 0 24th February 2007 06:06 PM
Page generated in 0.08110 seconds (77.07% PHP - 22.93% MySQL) with 10 queries
