Help a newbie build his first amp (powercaps for a 2024)
Old 4th June 2011, 10:12 PM   #11
Solid E is offline Solid E  United States
so ESR will drop the voltage?
Old 4th June 2011, 10:49 PM   #12
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
ESR limits how quickly the capacitor can take or supply current.
PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 4th June 2011, 11:08 PM   #13
So is there an easy way to know what a good rating for the capacitor would be in this application?
Old 4th June 2011, 11:11 PM   #14
A low ESR cap would be a good start.
Old 4th June 2011, 11:12 PM   #15
know of a good source?
Old 4th June 2011, 11:16 PM   #16
try US - Electronic Components Distributor | Newark.com
Old 5th June 2011, 05:50 AM   #17
Is anyone able to comment on my questions about capacitor uF and volt ratings?
Old 5th June 2011, 12:42 PM   #18
Davet is offline Davet  United States
Default ESR and Caps
The Caps listed on the Mardis site are Digi-Key - P12384-ND.
The caps you have should work fine. If you are trying to "optimize" the performance then do the research on the low ESR capacitors, but I think this may be over kill at this point in time. To get more bass from the amp the caps you have should be up to the job.
Davet
Help a newbie build his first amp (powercaps for a 2024)Hide this!Advertise here!
Help a newbie build his first amp (powercaps for a 2024) Solid E Chip Amps 6 19th May 2011 05:17 PM
Changing JAMICON powerCaps to WHAT?? Arcam Alpha amp stifa Parts 1 14th November 2006 03:35 AM
Newbie want to build simple tube preamp&psu!need help! thomgun_lc Tubes / Valves 55 29th November 2005 02:08 PM
New 2024 amp and mod site Andrewbee Class D 4 2nd October 2005 01:50 PM
Newbie, wanting to build Amp PaulHilgeman Solid State 3 8th January 2003 02:24 AM
Copyright ©1999-2017 diyAudio
