| Class D Switching Power Amplifiers and Power D/A conversion |
Hi there!
Yes, I used the search but didn't find the right answer... I got my Sure 2024 2x15W board today. The problem is it only "plays" for half a second when I pull the plug out. Me too stupid? What could be the cause? Have a nice day Felix |
#2 |
I use an old 300 watt ATX computer supply with a jumper between ground and a wire. I forget what it is called. Without that jumper it works just as you described. Also very important to have the ground wire to the amp be short and fat to cut down on noise due to voltage difference from input ground. I cut off the molex and used two of the ground wires to connect. Also the same for the 12 volt lines although that is not as important.
#3 |
#4 | |
I will now go to a friends house to try a different power supply. This one is 12V 2,5A, so maybe it is a little to weak?! Thank you guys! Felix |
#5 |
with a different power supply it now runs sweet...
| omitting lowpass using tripath TA 2024 | LineArray | Class D | 4 | 22nd October 2009 07:12 PM |
| Aluminum 2024 | jaudio | Parts | 0 | 22nd November 2005 11:53 AM |
| New 2024 amp and mod site | Andrewbee | Class D | 4 | 2nd October 2005 01:50 PM |
| Does the 2024 have magic the 2021b doesn't? | dgo | Class D | 3 | 29th May 2005 09:16 PM |
| Page generated in 0.07495 seconds (73.35% PHP - 26.65% MySQL) with 10 queries |
