sure 2024 power supply
Old 11th May 2011, 09:06 AM   #1
wawotam is offline wawotam
Default sure 2024 power supply
Hi there!
Yes, I used the search but didn't find the right answer...
I got my Sure 2024 2x15W board today.
The problem is it only "plays" for half a second when I pull the plug out.
Me too stupid?
What could be the cause?
Have a nice day
Felix
Old 11th May 2011, 09:51 AM   #2
ted4412wilt is offline ted4412wilt  United States
I use an old 300 watt ATX computer supply with a jumper between ground and a wire. I forget what it is called. Without that jumper it works just as you described. Also very important to have the ground wire to the amp be short and fat to cut down on noise due to voltage difference from input ground. I cut off the molex and used two of the ground wires to connect. Also the same for the 12 volt lines although that is not as important.
Old 11th May 2011, 10:32 AM   #3
kubeek is offline kubeek  Czech Republic
Send a message via ICQ to kubeek
Why should it behave differently? You cut the power, the power goes out.
Old 11th May 2011, 11:54 AM   #4
Noob, not stoop! It only plays in this half second. Otherwise it is dead.
I will now go to a friends house to try a different power
supply. This one is 12V 2,5A, so maybe it is a little to weak?!
Thank you guys!
Felix
Old 16th May 2011, 09:08 PM   #5
with a different power supply it now runs sweet...
sure 2024 power supplyHide this!Advertise here!
omitting lowpass using tripath TA 2024 LineArray Class D 4 22nd October 2009 07:12 PM
Aluminum 2024 jaudio Parts 0 22nd November 2005 11:53 AM
New 2024 amp and mod site Andrewbee Class D 4 2nd October 2005 01:50 PM
Does the 2024 have magic the 2021b doesn't? dgo Class D 3 29th May 2005 09:16 PM
Copyright ©1999-2017 diyAudio
