trouble after adding pot/RCA selector, help
Old 8th May 2011, 03:15 PM   #1
gychang is offline gychang  United States
Default trouble after adding pot/RCA selector, help
I have modified Helder's t-amp, and installed the volume, and 2 way RCA selector. Initiailly seems to work OK, but now I noticed, the volume is rather high on the L speaker even when the pot is all the down. Only when I turn it on beyond the half way, the other speaker (R) seems to come alive.
Switching the speaker wire confirms it is likely amp. Can someone tell me how to trouble shoot this?
thanks,
gychang
Good sound from Davis, CA
Old 11th May 2011, 12:56 PM   #2
robywan is offline robywan  Australia
Check your wiring on the pot, possibly the input wire coming from the input selector for the left channel is going to a pin other than number 3 connector pin on that Alps pot
Potentiometers (Beginners' Guide to Pots)
Pin one should go to ground, pin 2 to input of amp, and 3 is input from selector.
Can you explain the wiring /colour and or pics of the RCA ins and Pot close up, that way we can see what each wire does
To rule out your amp as the culprit disconnect your new wiring between the amp and the pot/selector and see if it does the same with direct input from a preamp or mp3 player with volume control.
Cheers
Toby
Old 11th May 2011, 04:21 PM   #3
Cheers
Toby
thanks for your input, I will check carefully the wiring as you suggested. I will also shorten the input wires to the amp.
gychang
Old 12th May 2011, 09:56 AM   #4
Glad to help let me know how you go :P
Old 12th May 2011, 01:37 PM   #5
thanks, resoldering and proper wiring, now the total background silence, sound beautiful, thanks,
gychang
Old 12th May 2011, 02:14 PM   #6
Thats awesome so pot wired was wired wrong?
Great
Old 12th May 2011, 09:51 PM   #7
Great
likely it was touching the next wire with my poor soldering technique, now all fixed.
gychang
trouble after adding pot/RCA selector, helpHide this!Advertise here!
What Volume pot and selector? Gobble Analog Line Level 7 21st July 2010 07:35 PM
Adding some RCA outs to a Tubelab amp bigjppop Tubelab 4 28th January 2010 02:52 PM
can I bypass my receiver's input selector and still use volume pot? bonjonno Solid State 9 20th February 2008 03:55 AM
Audiosector kit: adding a pot alleycat Chip Amps 26 26th February 2007 11:09 PM
Adding a pot to an amp6 jwb009 Class D 2 24th October 2006 02:33 PM
