| Class D Switching Power Amplifiers and Power D/A conversion |
Hi All,
Just cased a TA2020 pcb from Helder audio. While I was measuring/checking everything I noticed something that may be perfectly normal, however, would like to check in case it could harm my preamp. Upon turning on the amp (without speakers and source) there is a 2.5v dc voltage between Input and Input Ground. Draining I and Ig with a resistor and this input offset goes and stays at 0v (draining the input capacitor I assume?) Turning off the amp the voltage reverses: - if voltage between I and Ig was the 2.5v from turn on, it drops to 0v - if voltage between I and Ig was zero because I drained with resistor, voltage drops to -2.5v With no source and speakers connected I can trim the dc offset on the outputs to zero. Should I be worried? Or is it normal for input cap to charge at power up? And why does the voltage reverse after power down? Many thanks! |
| cmoy with 1uF input cap, DC offset from source still getting through | morfic | Solid State | 11 | 5th August 2009 01:41 PM |
| DC Offset on the input of a Threshold SL10 | hifi-hospital | Solid State | 10 | 25th February 2007 08:26 AM |
| BOSOZ input DC offset tolerance | Henry Pootel | Pass Labs | 5 | 29th December 2005 11:53 PM |
| Single-ended input to balanced output, no DC offset | LineSource | Solid State | 16 | 19th October 2005 09:32 PM |
| *technical elec question* DC offset/input impedance relation | homer09 | Chip Amps | 31 | 15th February 2005 01:42 AM |
| Page generated in 0.06620 seconds (67.28% PHP - 32.72% MySQL) with 10 queries |
