| Class D Switching Power Amplifiers and Power D/A conversion |
Hi, evry!
I'm relatively new to class-D amps, to begin with. In many designs one can see a 15V zener in gate-source net of the power stage FETs. 1. What is the goal of putting them there? 2. While bootstrap nets are sometimes 12V, why using 15V zener? Thanks. |
#2 |
The high side gate drive supply rail is usually produced from a resistive divider at startup and then from bootstrapping when the amplifier is switching. The resistive divider needs a zener for voltage limiting (although it may be included in the driver IC sometimes).
Switching speed (di/dt and dv/dt) is strongly dependent on gate drive supply voltage, another reason to ensure it does not get too high. Additionally, some degree of regulation in gate drive voltage can improve switching timing accuracy and reduce open-loop THD. Sometimes MOSFET fail with a gate to drain short. In these circumstances a zener (with the help of schottkys to clamp driver output to the rails) can reduce the amount of damage to the drive circuit (zener should fail shorted due to overcurrent, then forcing a properly sized gate resistor to fail open before PCB tracks start to blow). And sometimes the zeners are just cosmetic... (circuit designers playing vodoo games, without deep functionality considerations)
I use to feel like the small child in The Emperor's New Clothes tale
#3 | |
Thank You. |
| Zener regulated power supply | hags | Power Supplies | 3 | 8th October 2007 03:58 PM |
| High Current Power Supply 12v, with zener on base | jacquesl | Power Supplies | 13 | 26th August 2007 05:30 PM |
| Suggestions for a high-power low noise Zener regulator ? | youyoung21147 | Power Supplies | 0 | 29th November 2005 11:48 AM |
| ono and zener regulated power supply | patriz | Pass Labs | 5 | 22nd October 2004 12:34 PM |
| Input stage zener diode ? | thylantyr | Solid State | 2 | 7th May 2003 09:06 PM |
| Page generated in 0.08231 seconds (70.21% PHP - 29.79% MySQL) with 11 queries |
