How to connect Hypex Molex to XLR?
Old 4th May 2011, 05:17 AM   #1
souldriver is offline souldriver  Switzerland
Default How to connect Hypex Molex to XLR?
Hi
I already have finished my first Hypexamp (400UCD SMPS 12000, Softstart) and now i have to connect the Hypex-Molex to RCA and XLR. The Molexwires have 1 red, 1 white wire and little separate black wire (see pictures below). I already have soldered the connection between RCA and XLR (is this correct?). So now, how i have to connect the Molexwires with the XLR? I would be very pleased to get some help!
Thanks a lot
Souldriver
Old 4th May 2011, 10:08 AM   #2
Nobody any idea!
Old 4th May 2011, 07:18 PM   #3
...Really?
Old 4th May 2011, 07:30 PM   #4
gazza49 is offline gazza49  United Kingdom
Q: I would like to switch from XLR to RCA and vice versa without the need of pulling the unused cable out of the amp.
A: That basically amounts to a source selector. Refer to http://www.hypex.nl/docs/wiring.pdf for information of how to wire an RCA connector to the UcD module. Install a DPDT switch to connect the hot/cold inputs of the UcD module to either pins 2/3 of the XLR connector or to the signal and shell contacts of the RCA connector. Note that pin 1 of the XLR connector is not switched, but remains hardwired to chassis. The RCA shell contact also remains hardwired to the chassis. This means that when the DPDT switch is set to RCA, the cold input of the UcD module is grounded via the RCA connector.
Old 4th May 2011, 08:15 PM   #5
Thanks Gazza for your help. i tried to get the wiring document from hypex but it looks like thatthis document isnt available anymore (404 error message). do you know where i could find this document somewhere else?
Thanks again
Old 4th May 2011, 08:37 PM   #6
sorry i dont,ive never built a hypex ucd amp,but when i wired up my icepower asp1000 amps i used the power amp daigram on this page
6moons audio reviews: JE Audio VL20 & VS70
Old 4th May 2011, 08:45 PM   #7
no problem and thanks for the link but i need to know how the molex stuff has to work. now i am looking to find this wiring document from hypex. again, thanks a lot Gazza
Old 4th May 2011, 09:07 PM   #8
have a look at this pdf it may help
http://www.diycable.com/main/pdf/exodus_docs.pdf
Old 5th May 2011, 04:16 AM   #9
Thanks Gazza. This is very interesting.
How to connect Hypex Molex to XLR?Hide this!Advertise here!
RCA to XLR cable, where to connect the sleeve? klitgt Parts 18 19th September 2017 06:48 PM
[HELP] Which Molex Terminals for CL240D10C dsolodov Parts 2 10th September 2010 11:11 PM
Hypex DS4.0 - XLR Tiff_Needle Class D 2 14th July 2010 11:48 AM
Is it possible to connect both XLR and RCA inputs at the same time into an Aleph 5 Rony1 Pass Labs 7 21st March 2010 04:42 PM
How to connect molex/ multipin connector lgreen Construction Tips 10 25th August 2009 01:26 AM
