| Class D Switching Power Amplifiers and Power D/A conversion |
can someone advise me on which amp to build?
I am looking to build a mono class D amp and have seen recommendation for the TPA3106D1 and the TK2050. They are both recommended but I dont want to build both. What do you recommend? They both seem equally simple and cheap and both meet my specs. Its a choice based on a feeling now, but i have no feeling one way or the other. |
#2 |
Hard to say without seeing the schematics.
They look like they'd be about the same. |
#3 |
Can you solder smd? Do you want to use it or is it just a gadget? Can you etch/drill? Do you have a PSU and if so, single or symmetric?
#4 |
Hi thanks for the responses.
I can solder SMD I will use it but I'm not an audiofile, but if one is better i might as well make that if its the same every other way. I have access to a board router. I have access to a desktop PSU but plan to run it off a battery if it makes a difference. I was planning to just buy a battery charger. I'm going to deal with the battery charging and circuits at a later date |
#5 |
If you dont want to do smd then you could consider an irs2092 class d amp.
It works fine so long as you keep the layout tight and the circuit well decoupled.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
| design & build 300w ot & pt | coreythompsonhm | Tubes / Valves | 2 | 10th March 2011 03:49 AM |
| Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 | quality sound | Tubes / Valves | 0 | 9th May 2009 03:59 PM |
| Build a Loud, Simple & Cheap amp for a friend | EWorkshop1708 | Car Audio | 5 | 19th April 2008 04:53 PM |
| Want to build car amp to run a couple of 12" subs | menaztricks | Chip Amps | 10 | 5th November 2005 04:39 PM |
| Build or buy? Logitech Z-680 & College student | donga | Multi-Way | 3 | 19th August 2004 08:09 PM |
| Page generated in 0.06680 seconds (78.86% PHP - 21.14% MySQL) with 10 queries |
