PCB for TAS5630 Should be ok for hand soldering
Old 1st May 2011, 07:22 PM   #1
Yoshy is offline Yoshy  Canada
Default PCB for TAS5630 Should be ok for hand soldering
Attached is Revision B of my PCB for a TAS5630; these chips look good on paper and I'd like to try them out. Revision A blew up in my face do to bad soldering; I've adjusted the spacing for my clumsy hands.
It's almost 1 layer; the second layer being only a ground plane, everything is as close as possible and inductors chosen have small lead spacing. +12 volts is generated on board.
This design should be compatible the whole series (TI has a few chips with the same pinout)
PCB will be 2oz copper.
Please let me know what you think.
Old 1st May 2011, 07:52 PM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
This is why I decided on a irs2092 system, available in PDIP and easy to solder.
PCBCAD51 pcb design software. 2018 version out now. http://www.murtonpikesystems.co.uk
Old 31st May 2011, 10:55 PM   #3
rs2512 is offline rs2512  Poland
Nice project. Did you tested this board?
Old 1st June 2011, 04:19 AM   #4
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
PCB for TAS5630 Should be ok for hand soldering Send a message via MSN to authlxl
nice job,but suggest try TAS5630PHD version.
PCB for TAS5630 Should be ok for hand solderingHide this!Advertise here!
TAS5630 pcb for sale Dimon74 Group Buys 6 21st April 2012 05:35 PM
Pencil CAD and Hand Carving PCB Traces Boofers Construction Tips 3 19th April 2011 02:09 PM
tas5630 pcb for verification udhay_cit Class D 6 22nd August 2010 07:37 PM
soldering parts to PCB spendorspain Parts 8 22nd April 2006 05:05 AM
Soldering temperature for PCB? jholtz Digital Source 4 6th June 2005 10:18 AM
Copyright ©1999-2017 diyAudio
