| Class D Switching Power Amplifiers and Power D/A conversion |
hi, i just finished wiring a small outdoor boombox with a ta2024, sounds great but i am only getting one channel output as it is a single speaker. is there a simple way to turn the stereo input into a mono output from the speaker? the friend i got the amp from seemed to think that only having one speaker attached would output the stereo source over the single speaker.
sorry i am typing this from my phone, apologies for mistakes. Also i am rubbish at trying to explain what i mean and dont know the lingo. thanks and regards! |
#2 |
Just connect the two channels together.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
how would i connect the two channels? it says not to short the outputs together as they arent on the same net.
thx |
#4 |
Then put 100r resistors in series with each channel then short them.
My ipod works fine with them shorted.
#5 |
A 100r resistor on each channel Then positive from one channels terminal to the others negative terminal and a wire between the other negative and positive? Sorry its been a while since i did any electronics at all, appreciate your suggestions.
#6 |
A 100r in series with each channel then join the output from the resistors together. Then connect the earths together.
#7 |
Thanks, think ive got it now.
#8 | |
#9 |
good job I hadn'tt ried that yet! Am i doomed to half power then? Bah sounds good anyways
| Help? Stereo to Mono Output Switch + Preamp Effect Box | kfung | Instruments and Amps | 0 | 4th January 2011 03:47 PM |
| Stereo output from mono source? Please help | Matt7783 | Digital Source | 7 | 4th July 2010 09:00 PM |
| Help me find a cheap, small stereo with optical inputs | purplefern5 | Everything Else | 3 | 25th September 2009 10:35 PM |
| unbalanced stereo out to mono summed balanced output | Original Burnedfingers | Solid State | 3 | 11th January 2009 05:45 PM |
| Stereo to mono via speaker output???? | rabbitz | Multi-Way | 1 | 8th August 2003 02:10 PM |
| Page generated in 0.09344 seconds (76.19% PHP - 23.81% MySQL) with 10 queries |
