| Class D Switching Power Amplifiers and Power D/A conversion |
Hello DIY'ers!
Because I don't have time to try to make my own amplifer board I'm going to try out some from Connexelectronics. I've choosen the following items: TDA8950TH w. heatsink configured in BTL for a 8 ohm subwoofer. Connexelectronic TDA8920BTH w. heatsink in stereo for my middle/high tones. Connexelectronic 500 Watt SMPS with +/- 31.5 Volt: Connexelectronic Will these two amplifiers work fine when working on the same supply? I think I've read something about that they could disturb each other because they might run on different frequencies. Regards, Simon H.A. |
#2 |
Well it is highly recomended to run the modules at the same frequency and that is why they can be syncronized by an external oscillator.. Depending on the supply filtering in the amp boards you may get some extra distortion and noise in the sound.. I have used two TDA8924 modules with the same supply and didn't get a very clear difference so I guess you should be fine.. |
#3 |
I think I'll just give it a try
| how to: multiple amplifiers? | nige838 | Solid State | 1 | 6th February 2011 01:19 AM |
| Multiple Amplifiers, one set of headphones | moronickaos | Headphone Systems | 0 | 6th June 2010 10:42 PM |
| using multiple amplifiers on one speaker | saltmiser | Everything Else | 6 | 15th February 2009 05:14 AM |
| Bias for Multiple Amplifiers | thespeakerguy | Chip Amps | 2 | 31st January 2009 08:09 AM |
| Question about active crossovers and multiple amplifiers | ogp | Everything Else | 5 | 5th October 2001 05:46 AM |
| Page generated in 0.08446 seconds (66.53% PHP - 33.47% MySQL) with 10 queries |
