Go Back   Home > Forums > Amplifiers > Class D
Old 26th April 2011, 03:04 PM   #1
Joku is offline Joku  Finland
Default TPA3122 doesn't work
I recently made a TPA3122 pcb myself. However, when I try to use it, I just hear clicking sounds from the speakers. Also, when inspecting it with oscilloscope, looks like it's trying to start (voltage at output goes up for a moment and then goes down a few times in a second). The schematic is basically directly from the datasheet.
Any ideas?
Old 26th April 2011, 03:40 PM   #2
picowallspeaker's Avatar
Did you check the s-by and the mute pins ?
Old 26th April 2011, 04:01 PM   #3
/SD needs to be connected to VCC through a pullup resistor, 10K or so. Also, AGND and PGND are not connected to each other and you don't have output DC blocking caps. Were you trying to use a split supply? That's not going to work. The TPA3xxx chips only work with a single supply.
Old 26th April 2011, 04:06 PM   #4
theAnonymous1's Avatar
Where are the output blocking caps? If you aren't using any, then that's your problem.
Also, where does AGND connect to PGND?
EDIT: "Ninja'd" by killer, as the kids say.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 26th April 2011, 05:30 PM   #5
I'm using it in bridged mode, so no output capacitors are needed. AGND and PGND are connected to each other at power supply (I'm using two of the chips to make a stereo amp), should they be connected on the PCB instead?
Also, do you have to use a resistor between VCC and /SD?
Old 26th April 2011, 05:43 PM   #6
That's not the problem then.
How are you bridging them? Are you running a balanced signal?
I don't on my working boards.
BTW, the 4.7k resistors on the output aren't needed if you are running it bridged. They are only there to drain residual voltage on the blocking caps when the amp is powered off.
Old 26th April 2011, 05:58 PM   #7
Just checked it out and SD is high and mute low.
Yeah, I turned the normal stereo signal into two balanced signals with an inverting opamp circuit. It has unity gain, so the plus input is straight from the potentiometer while the minus input is from the opamp.
Old 26th April 2011, 06:10 PM   #8
Hmm, the bridged output schematic in the datasheet had them, I don't know why.
Old 26th April 2011, 07:03 PM   #9
Here's the schematic I used for preamp
Old 26th April 2011, 07:08 PM   #10
Have you tried playing the amp without the pre-amp circuit attached?
Try connecting one of the inputs to ground and playing a single ended signal through the other input. Still connect the load to both outputs just like BTL though.
Only half the bridge will play, the other half will just provide DC bias so you don't have to install blocking caps. That will at least tell you if the pre-amp circuit is causing a problem or not.
TPA3122 - not working. Nothing aviatorbja Class D 17 26th July 2011 06:10 PM
TPA3122 aditya Class D 2 10th April 2011 10:23 PM
TPA3122 for driving external MOSFET's Cyberzim Class D 2 23rd April 2010 11:22 AM
TPA3122 Groundings Cyberzim Class D 6 18th September 2009 11:28 PM
Class D TAS 5261/TPA3122 jash2008 Class D 13 3rd August 2009 05:35 PM
Page generated in 0.11153 seconds (78.13% PHP - 21.87% MySQL) with 11 queries
