TPA3122 doesn't work - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 28th April 2011, 06:42 PM   #31
theAnonymous1's Avatar
Originally Posted by Joku View Post
Oh, you didn't design it with a CAD program?
Not a proper one.
I use Pad2Pad and lay out everything manually. Netlists make me angry.
Old 1st May 2011, 09:23 PM   #32
Joku is offline Joku  Finland
Btw, I solved the issue, I just had to add a low pass filter to the input.
Old 1st May 2011, 10:08 PM   #33
Also, here's the new PCB I made (+ masks), this one is SMD. (the mask has four of them because I made a stereo one, and masks printed with a laser printer work better if you use two of them on top of each other)
Old 2nd May 2011, 11:00 AM   #34
Now it works otherwise fine, but it still has one problem: you hear a high-frequency whine from the speakers, which I suspect is the difference between the switching frequencies of the two amps. I tried to regulate the voltage supply to the preamp, but this didn't help. Also, this whine isn't heard when the inputs aren't connected, so I suspect it's because of the preamp.
Old 19th November 2011, 02:05 PM   #35
i have the same problem,too
Old 19th November 2011, 02:07 PM   #36
TPA3122 - not working. Nothing aviatorbja Class D 17 26th July 2011 06:10 PM
TPA3122 aditya Class D 2 10th April 2011 10:23 PM
TPA3122 for driving external MOSFET's Cyberzim Class D 2 23rd April 2010 11:22 AM
TPA3122 Groundings Cyberzim Class D 6 18th September 2009 11:28 PM
Class D TAS 5261/TPA3122 jash2008 Class D 13 3rd August 2009 05:35 PM
Copyright 1999-2017 diyAudio
