TPA3122 doesn't work - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 27th April 2011, 02:18 PM   #21
theAnonymous1's Avatar
Originally Posted by Joku View Post
I used an electrolytic capacitor as the 10 capacitor, is that fine?
Yes that's fine, and you have it reasonably close to the supply pins.
I would start with replacing the boostrap capacitors with X7R ceramics.
Old 27th April 2011, 03:27 PM   #22
C3 and C4 are plastic capacitors, I don't know if they are low-esr or other special capacitors.
That there may be part of your problem. C1-C5 should all be monolithic ceramic caps. Inductively wound caps (rolled foil) can cause many problems in high speed switching circuits. There's a reason you see all those little chip ceramic caps next to IC's on modern digital PCBs instead of standard film types.
Old 28th April 2011, 02:51 PM   #23
Joku is offline Joku  Finland
Tried switching them to ceramics, didn't work.
Originally Posted by theAnonymous1 View Post
I've built quite a few different PCB iterations using this IC and they have all worked (and I'm no professional by any means). Some had hum from bad grounding, but they did work.
Would it be possible to get the layouts and masks (just as a gif file), I would like to try out some of them?
Old 28th April 2011, 04:06 PM   #24
I really don't think my layout will be of much use. It uses 1uF 100V X7R ceramics for every cap except the main power caps and 100nF decoupling caps.
The board is double sided and all the ground pins are soldered to the top side ground plane.
Old 28th April 2011, 04:16 PM   #25
Thanks, but a plain gif file would be more useful (I would need to make a negative mask) if it's not too much trouble.
Anyways, what do you mean with it not being of much use?
Old 28th April 2011, 04:57 PM   #26
Sorry, the program I use doesn't have an option to output/save as a GIF. I'm sure you can take the PDF I posted and convert it somehow. I don't have time to figure it out right now though.
Well, I just meant unless you have the exact parts I used you will have to do a lot of improvising.
Old 28th April 2011, 05:28 PM   #27
OK, I don't know if this is what you were looking for, but I gave it a shot anyway.....
Old 28th April 2011, 05:55 PM   #28
Yeah, that's what I was looking for. Thanks
I have SMD components around, so I can probably figure out something. If you can send a picture of layout (with component values), that would be nice too.
Old 28th April 2011, 07:01 PM   #29
I don't know when or even if I would be able to do that. I don't even make those notes or diagrams for myself as I find it tedious. I just rely on memory.
I think the best I can do for you is show you pics of a different version of the board I made and let you try to reverse engineer it a bit. It's a simple enough circuit.
My TPA3122D2N BTL proto
I will mention there are three "vias" that are just wires soldered from the ground plane to pads on the bottom. One is near the gain jumpers and the other two are on the ends of the output filter caps.
Sorry, that's the best I can to right now.
Old 28th April 2011, 07:30 PM   #30
Oh, you didn't design it with a CAD program?
TPA3122 - not working. Nothing aviatorbja Class D 17 26th July 2011 07:10 PM
TPA3122 aditya Class D 2 10th April 2011 11:23 PM
TPA3122 for driving external MOSFET's Cyberzim Class D 2 23rd April 2010 12:22 PM
TPA3122 Groundings Cyberzim Class D 6 19th September 2009 12:28 AM
Class D TAS 5261/TPA3122 jash2008 Class D 13 3rd August 2009 06:35 PM
Copyright 1999-2017 diyAudio
