Go Back   Home > Forums > Amplifiers > Class D
Old 26th April 2011, 02:48 PM   #1
Default Can this amplifier be bridged?
I find this class D amplifier kit on ebay:
TDA8920 CLASS D Audio Power Amplifier AMP Kit 100W X2 | eBay
It seems very inexpensive (if it works). Anyone knows if this amplifier can be bridged?
Thanks.
Old 26th April 2011, 04:01 PM   #2
LAJ is offline LAJ  United States
Default Probably not
The concept of bridging requires that one of the inputs (of a stereo amp) be inverted. This can easily be accomplished with balanced inputs but its my guess that this amp probably has unbalanced inputs.
Old 26th April 2011, 04:29 PM   #3
You are right. The input has three terminals (-, + and GND), if that is what you mean by "balanced input". What if I connect one input to the - and +? Is that equivalent to bridging it? Thanks a lot.
Old 26th April 2011, 04:39 PM   #4
An inverter is a mystery? The limiting factor is output current capabilities.
Old 26th April 2011, 05:18 PM   #5
macboy is offline macboy  Canada
This definitely can be bridged, but you will need to provide an inverted signal at one input (either L or R). The +/-/GND "input" that you see is the connection for the power supply. The input signals are on the little white connector.
If you look up the TDA8920 you will see that it is a 2 x 50 W chip (or 2 x 80 W depending on which datasheet you find), and it can be operated in bridged mode. In stereo mode and 8 ohm load, the output at 0.5% distortion is only 30 W x 2, and rises to 39 W x 2 at 10% which isn't music any more, it's garbage. With 4 ohms, it can do 80 W x 2 at 10% distortion. In mono bridged mode and 8 ohms, it manages 79 W at 0.5% and 100 W at 10%. My point is, don't believe for a second the "100 W x 2" in the auction title. It is a lie. And if they lie about that.... what else? Do you trust them enough to send your money? And do you even want this if it does only 30 W/ch not 100 W?
Controversy regarding Bridged Amplifier power output RishiGuru Chip Amps 89 25th May 2012 02:34 PM
2 stk4050v bridged amplifier noubar Chip Amps 16 19th July 2011 06:11 PM
Im BAAAACK! Marathon amplifier question, won't work bridged mono! 240z4u Car Audio 11 3rd April 2008 02:56 AM
How do you bridge two bridged amplifier? thylantyr Solid State 41 15th October 2003 10:30 PM
Sound of bridged amplifier Gabevee Solid State 17 23rd July 2002 09:01 PM
Page generated in 0.07948 seconds (74.05% PHP - 25.95% MySQL) with 10 queries
