| Class D Switching Power Amplifiers and Power D/A conversion |
Hello, Recently I've been hanging around those all-in-one package chips that philips offer and I gotta tell you they sound pretty good but my problem is that the inductors that I use run at 40-50C degrees or so no matter on the load conditions.. I was told by many people that I needed the iron powder cored ones but this stuff always gets on my nerves what inductors should I use for this?
switching frequency is around 310kHz currently I have setup on the LC a 15uH 6A iron powder core inductor (link below) and a 1uF cap. VISHAY DALE|IHLP4040DZER150M11|INDUCTOR, 15UH, 20%, 6A | Farnell United Kingdom |
#2 |
Roll your own?
41Hz Audio:Sounds Good to Me! |
#3 |
Get a t106-2 core and wind your own with a couple of meters of 18 SWG enamel coated copper wire.
Amidon do the cores but you can pick them up on ebay too.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#4 |
The toroid color tells the material right?
Is it OK to go with blue/green one cause I've got one at hand? BTW is it normal that the amp runs alot hotter at idle than in operational use? |
#5 |
thanks btw
#6 |
The t106-2 is red.
Colour denotes material. -2 is the material and 106 is the diamter.
#7 | |
I run my class d amps at 200KHz and they dont get hot at idle. The toroid shouldnt get warm either.
#8 |
These are the ones you want....
2 Two Toroid T106-2 Micrometals T-106-2 Torroid | eBay ~33 turns will get you close to 15uH.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#9 | |
Also if I wind my own toroid is it better to use a couple thinner wires or a single thick one? |
| Notch filter inductor question | IG81 | Multi-Way | 2 | 11th November 2010 06:23 PM |
| heating in inductor ( LC Filter ) | yanuarbob5150 | Class D | 3 | 23rd September 2008 10:19 AM |
| smps output filter inductor design | zilog | Power Supplies | 7 | 30th August 2008 11:47 PM |
| SMPS Output filter inductor calculation. | corrieb | Car Audio | 7 | 28th October 2005 03:47 PM |
| ~30mH inductor for use in pi filter | Zodiac | Parts | 6 | 29th September 2003 10:38 AM |
| Page generated in 0.09721 seconds (74.79% PHP - 25.21% MySQL) with 11 queries |
