| Class D Switching Power Amplifiers and Power D/A conversion |
Hi Guys
As a bit of a beginner I'm not sure what I can get away with re connecting things together. I was hoping to do some A-B testing o two amps, using a separate Squeezebox Touch to supply each amp & connecting both amps to one set of speakers at the same time, with the idea of playing music through each amp one at a time. This would save me building a switching device. If I cannot do that, does anybody have a simple design for a switch? |
#2 |
I wouldn't drive other amps output with first, I would use switch or relay there
#3 | |
![]() Wouldn't electrical relays cause some horrible noises when switching? I assume I would need two double pole relays and wire one amp out put to the two Normally On side of the two relays & the other amp to the Normally Off side of the relays, you can see I'm a genius at all this. )
#4 |
well if you would turn down the volume, then I don't think there would be any noise... if you need to keep constant volumes on both amps, then you will just have to go and switch when you need to... maybe I would also use 10R resistor, for each amp ch to drive when it doesn't have any speaker on
Maybe I am going to far with this, but.. |
#5 | |
Why not just purchase a cheap speaker selector switch? That will allow only one amp at a time to be connected to the speakers. If any of the amps are tube amps you'll need to make sure you either place a resistor across the output terminals of the amp (20 ohm would probably not interfere with the sound but would prevent over voltage) or just be careful to keep the volume at zero until the speakers are connected. |
#6 | |
I also would like to A/B two Tripath amps on one set of speakers, but as I understand it, Tripath amps cannot share the right and left negative terminals, as most other amps typically do. I have been looking but have yet to find a speaker selection switch that does not connect the negatives together to save space and cost.
Anybody have a solution to that problem? I'm about to build a switch of my own with a 4-pole DT switch of some kind. From an eBay site selling the Lepai's: Quote:
Shrink to Patient: "Forget the Prozac, you need more Boogie!" There are only two kinds of music. Good and Bad |
#7 | |
#8 | |
#9 | |
Ideally, I would like to eventually be able to switch between two amps and also two sets of speakers. Not sure what kind of switches would be suitable for that.
#10 |
Well here it is. I haven't tried it yet, but it is testing fine. I need to make some split RCA leads or else I can us my two Squeeze-boxes, synchronised I guess, then wont need the split leads. Any thoughs on what would be the best approach?
I'll be testing an Integra Class A-B amp against a DIY D class, I not sure If I will need a dummy load for the amps when they are not linked to the speakers, but have bought some 8.2ohm 10w wire wound resistor for that purpose if needed. Any thoughts guys on if the dummy load will be needed? I have a illuminated switch, that switches two 12V 30amp relays, there is a LED so you know when the unit has power, the who thing is powered by my computer backup drive power supply. I plan on torturing the kids & brothers (or anyone silly enough to get to close to the house) by making then listen to the amps & giving there opinion on which sounds the best to them, they wont know which amp is on, but I will know because the illuminated switch will be way of keeping track. When I try it myself I will try to make my assessment before confirming which is which. My thanks to the designer, Phil Allison, A-B Box For Amplifier Comparisons Last edited by DQ828; 24th April 2011 at 10:12 AM. |
| Sub testing for T/S | ZippyTs | Car Audio | 6 | 5th November 2009 09:09 PM |
| testing, testing 123 | neil_kaye | Full Range | 0 | 25th December 2005 08:21 PM |
| Page generated in 0.14994 seconds (84.13% PHP - 15.87% MySQL) with 11 queries |
