Sure 4x100 as 2.1 setup
Old 17th April 2011, 07:44 PM   #1
tacobeast is offline tacobeast  United States
Default Sure 4x100 as 2.1 setup
I am wanting to run a sure 4x100 amp in a 2.1 configuration for computer speakers. Since the outputs can't be bridged I was just thinking that I could run a DVC sub off channel 3/4, would that work, or is there a better way? Also I will need to wire up a pot for volume control. Is there a wiring diagram that shows a master volume control and then also a fade control to control the sub relative to the main speakers? Thanks for your help!
Old 17th April 2011, 08:13 PM   #2
Arty is offline Arty
DVC sub is a nice idea.
That should work.
or 2 subs, if you like.
Or, if you are short in space / wanna fancy things, an isobaric sub may be even a verry nice choice.
Suposedly You can wire up 2 pots.
1 as master volume, and the other to controll the sub.
Sub's pot takes input from the master pot output.
Old 17th April 2011, 08:19 PM   #3
sofaspud is offline sofaspud  United States
sofaspud's Avatar
It seems like a workable idea to me. I would just use 2 regular pots for the L-R channel inputs (so I also had balance control) and a dual-gang pot for the sub inputs.
Old 23rd April 2011, 04:03 PM   #4
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I have moved this thread over here and closed the other one.
planet10 needs your help:
Let's help Ruth and Dave
Sure 4x100 as 2.1 setupHide this!Advertise here!
Sure TK2050 4x100 PLLXO & volume? Madumi Class D 1 25th November 2011 04:41 AM
Using PC PSU for Sure 4x100 amp board RhinoDude Power Supplies 2 14th September 2010 05:11 PM
Help: Aletc AC7300 4x100 amp StRaNgEdAyS Car Audio 2 12th August 2007 09:36 PM
Best setup BluesHead Digital Source 3 29th June 2003 04:53 PM
setup trip-wire Everything Else 2 2nd January 2003 04:30 PM
Copyright ©1999-2017 diyAudio
