| Class D Switching Power Amplifiers and Power D/A conversion |
I designed for myself a different sort of class D amp. It is two switchers running out of phase with the outputs coupled with inductors. The audio is fed out of phase to the two amps. With no audio input there is no ripple at the output. When there is audio the resultant summed pulse input to the filter appears at twice the switcher frequency making it easier to filter.
Have I invented something or has this been done before? |
#2 |
This has been done for power supplies; it's called interweaved. LTC calls it polyphase. I suppose it would work fine for Class D amps as well.
#3 |
I think you have made yourself a three-level pwm and suggest you read a bit on "filterless class D" and "multilevel pwm". Also, I believe its 'interleaved' rather than 'interweaved'.
#4 |
#5 |
The main reason you don't see this in commercial class D amps is mostly cost. Why spend double the amount on output transistors and inductors for less than a 1% improvement in the amount of distortion or efficiency? The only class D configuration that benefits from this is high current PDM. You use lower cost, slower mosfets with low output impedance in a dual or tri phase arrangement and significantly reduce losses. It's common in computer motherboard voltage regulators designs because of this.
#6 |
My reason for doing it was because I designed my own FET drivers using just simple small signal transistors (2N2222 and 2N2907) My output FETs are taking 250ns to switch making it inefficient to run over 100kHz. I would like to find a simple driver circuit that could speed this up. I am using +/_ 40 volt supply rails. I have used IR2112 drivers before but they only work from a single supply making it necessary to use a H bridge.
I am new to this stuff so any links would be greatly appreciated. |
#7 |
How is the current sharing between the switching stages of your multiphase (that's the correct name) arrangement?
#8 |
I am using overall feedback with all DC coupling so there is only a few millivolts offset between amps. The output inductors measure .3 ohms so there should be less than 100 milliamp difference current flowing. I only have this working on a breadboard and will scrap the idea if there better drive circuit do use and just stick with a single output stage.
#9 |
three hundred miliohms ???
What's the amp's rated power? Last edited by darkfenriz; 16th April 2011 at 11:44 PM. |
#10 |
Since the inductors are effectively in parallel the resistance is .15 ohms. I just wound some air core coils about one inch in diameter that measure 50 uh so in parallel they look like 25.
I plan on getting about 100 watts at 8 ohms out of it. I am learning this as I go and welcome feedback as to what I am doing wrong. I really need to find a way to drive FETs fast. The rise and fall times on the FET gates is 100ns with a 50ns delay to prevent both being on at the same time. I think there must be a simple way to speed this up. It's being done on a prototyping board so that might be part of the problem. |
| measure amplitude of modulated signal | Bernhard | Equipment & Tools | 5 | 13th August 2009 12:25 PM |
| Modulated cascode and positive feedback? | Circlomanen | Pass Labs | 4 | 13th March 2006 01:14 PM |
| 300W 'modulated bias' cascode Killer Amp | amplifierguru | Solid State | 56 | 28th December 2005 04:48 AM |
| Direct Coupling Modulated Bias (SET) | serengetiplains | Tubes / Valves | 59 | 10th February 2005 08:28 PM |
| MODULATED lobing and response | Bill Fitzpatrick | Multi-Way | 43 | 2nd March 2004 10:58 AM |
| Page generated in 0.11066 seconds (80.30% PHP - 19.70% MySQL) with 10 queries |
