| Class D Switching Power Amplifiers and Power D/A conversion |
Hi. Is boot strap a kind of level shift or what's the difference? I see some circuits using both these methods, why? Thanks.
#2 |
Boot strap is usually where positive feedback is used to increase the input impedance.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
In ClassD the bootstrap usually refers to a power supplying method of high side gate driver. Level shifting is a different thing, but often they go together.
#4 |
Level shifting in class d is altering the levels of the signals to match the mosfet driver.
The output of the comparator is usually based around zero volts and the input to the mosfet driver is based around B-.
#5 |
Thanks but not enough to make me understand though, could you try to explain a bit more, treat me like a noob, cause that's what I am.
#6 |
Pafi says right on the bootstrap method. Level shift is used when there is a potential difference between the stage of the mosfet and the stadium before (this is often referred to GND). usually resolves with two bjet the low side MOSFET (VN) |
#7 |
This can usually be done with a single transistor stage.
#8 |
It depends on what is the potential difference.
consider that this stage is critical for the transient response, and then must work with low load resistances. this (depending on the voltage difference that must absorb) the energy will dissipate. |
#9 |
With my discrete class d amp I had to shift grom +12v/0v to -35v/-20v and a simple transistor stage worked fine. I did put a diode to the -20v rail and a resistor in series with it to clip the voltage. Worked very well.
I have also seen another design with a very similar circuit.
#10 |
Ok, so a level shift is not necessary to drive the upper transistor, the boot strap is? And a level shift might also be needed in some cases? I'm sorry it's a bit hard to understand, all these English terms.. If anyone has time and wants, a picture might help. Sorry for being slow.
| Need help choosing level shift and inverter | levelshift | Class D | 4 | 27th March 2011 05:47 PM |
| How do we calculate the values of the boot strap resistors ? | tessier | Solid State | 4 | 8th October 2010 11:27 AM |
| Level difference on ESL. | sholby | Planars & Exotics | 7 | 5th July 2005 04:56 PM |
| A better triode strap? | G | Tubes / Valves | 10 | 19th December 2004 09:58 AM |
| A better triode strap? | G | Tubes / Valves | 14 | 2nd June 2004 12:36 AM |
| Page generated in 0.10129 seconds (78.77% PHP - 21.23% MySQL) with 10 queries |
