Go Back   Home > Forums > Amplifiers > Class D
Old 22nd March 2011, 08:33 AM   #1
Send a message via MSN to Commited
Default What TK2050 amp?
Hi guys,
I've recently moved to Australia (was only meant to be a holiday...), so I'm effectively starting my system from scratch again. I'm building some BIB boxed Fostex FE206En speakers in the next couple of weeks, but I want a nice amp to drive them. I've had modified T-amps & charlize amps in the past and really enjoyed them, so I'm looking at the TK2050 amps now. There seem to be a lot of options out there and I'm just looking for opinions from people much better judged than I!
Sure Electronics 2*100w, volume board & 27V SMPS - $103.40 + box
Hifimediy T2 & Meanwell 27v SMPS - $115 + RCA + speaker posts + box
Dayton DTA-100A - $118.60
(prices in AUD and including shipping)
As I'm in a new country, I have none of my stuff here, so I'm starting from scratch. I do have a rough chassis I can use for an amp though. I don't want to modify the board.
I was leaning towards the Sure electronics board until I found the Dayton and I'm slightly leaning towards it for simplicity factor. However, if it's significantly worse than the other two than I don't want to compromise. Are there any other boards I should consider? Budget is about $150 maximum!
Some opinions would be greatly appreciated!!
Old 22nd March 2011, 09:42 AM   #2
Saturnus's Avatar
A pair of 41hz amp11-hv...
Old 22nd March 2011, 05:15 PM   #3
julcat is offline julcat  Mexico
The Helder modules are as good or maybe better than the highly regarded Virtue Audio Amps
2 pcs,Brand New MKII TK2050 monoblock class-D amplifier on eBay (end time 03-Apr-11 04:42:14 BST)
Old 22nd March 2011, 10:31 PM   #4
Saturnus - thanks for the reply but I'm not set up here for kit building!
julcat - I hadn't seen or considered these. They come out as quite expensive in comparison when coupled to the tube pre-amp ($133 more), are they worth it?! Will the tube pre-amp run off 27v?
Old 22nd March 2011, 11:20 PM   #5
Bernie7 is offline Bernie7  Singapore
You can't go wrong with hifimediy T2. I have the T3 and it compares very favourably with my UCD400HG monos
Old 23rd March 2011, 02:53 AM   #6
The Helder Tube Preamp works with 12 volts, i change the input caps on the amps with auricaps and they get even better, very musical, detailed and tube like sound.
FS: TK2050 Hifimediy AMP mravlca Swap Meet 6 28th April 2011 10:19 PM
tk2050 amp in a boombox Detrick Kingman Class D 18 25th February 2011 11:33 AM
TK2050 Amp kunalraiker Class D 4 24th November 2010 03:18 PM
Biamp TK2050 with tube amp - any benefit ? hillbear Class D 13 2nd October 2010 01:33 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Page generated in 0.09044 seconds (72.44% PHP - 27.56% MySQL) with 10 queries
