| Class D Switching Power Amplifiers and Power D/A conversion |
Hello, anybody have worked on HIP4081A MOSFET driver IC.............
I went through Application note of HIP4081A. I could not understand the bootstrap capacitor calculation, the formula is given as CBS= {Qg + Qrr + (IDR +IQBS)/fPWM}/(VBS1-VBS2) during the calculation it is said that the value of IDR and IQBS is negligible so the simplified formula becomes as CBS = (QG + Qrr) / (VBS1-VBS2) where, Qg= Turn on gate charge transferred (Which can be taken from MOSFET datasheet) Qrr= Bootstrap diode reverse recovery charge (which can be take from diode spec sheet) VBS1= bootstrap capacitor voltage just after refresh VBS2= bootstrap capacitor voltage just after upper turn on I dont how what value should I take for VBS1 and VBS2 The example which is given there, has taken (12.0 - 11.0) I dont know how........ you can have a look at the file by this link http://www.intersil.com/data/an/an9405.pdf at eq:3 on page 6 and eq:4 on page 7. if you could explain..... Thank you. Regards, Dileep |
#2 |
Well that is basic calculation, for min capacitor size needed.. you can always just use 10u-100u and don't calculate anything
#3 |
Ok, thank you luka.
| Mosfet Quiet Bootstrap | acoustixman | Power Supplies | 1 | 16th October 2010 12:15 PM |
| Another thread regarding CCS vs BOOTSTRAP | Nico Ras | Solid State | 83 | 7th December 2008 12:00 AM |
| Why bootstrap? | peranders | Solid State | 52 | 27th December 2007 04:25 PM |
| Aleph amp bootstrap - where to go? | Klaus | Pass Labs | 5 | 28th May 2003 09:48 AM |
| Page generated in 0.06621 seconds (70.60% PHP - 29.40% MySQL) with 10 queries |
