Boombox no.2! :D - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 21st March 2011, 08:10 PM   #21
Oh god i feel stupid >.<
So the idea i had from the begining is the best? :P
But if so, will this do it? http://www.clasohlson.se/Product/Pro...x?id=161192396
EDIT:
Just realised my coaxials stick out 75mm and not 100mm as i thought.
25mm x 2 = 50mm and just checked, that's enough to the magnets not pulling each other away too much
So don't think i will need those things
But is there anything else that could make the boombox better?
Im starting building it on wednesday so after that, its too late
Old 22nd March 2011, 07:54 PM   #22
Ok then, i'll start the building tomorrow
Wish me good luck ^^
Old 31st March 2011, 07:28 PM   #23
Got the AMP9-B now, starting soldering tomorrow, need to study the instructions a little more before being sure
Great delivery, ordered it yesterday at 7pm, got it today at 12am!!
41hz is in sweden like me, but still, one day is just crazy!
Old 5th April 2011, 07:01 PM   #24
I am almost done soldering, but i dont have any more solder :/
Going to buy a 250mA fuse, a fuse for when im running it on higher power(how much A do i need? im going to use both a 12v system and a 24v system, perhaps 6A?),
more solder and a heatsink
Also, im looking for a very cheap pre-amp.
Would this one work? $13.80 - Digital Audio MP3 Player Module with Remote Controller (1.5" LCD) - DIY Parts & Components
Will it work to plug in the speaker outputs to my amp input?
Will it be more than 12V output?
If so, will it work to put a resistor to make it 5V?
I think the amp max input should be at 5V, not sure.
Old 7th April 2011, 07:00 AM   #25
No awnsers -.-
Btw, wouldn't it word to connect a aux cable directly to the input?
The output of an 3,5mm is also 5V, so why wouldn't it?
And perhaps just connect a potentiometer so i can change the volume from more places than just my audio source, would that work?
Cal's little boombox Cal Weldon Multi-Way 33 3rd December 2010 07:36 PM
Boombox in a car ashhegde Car Audio 2 11th June 2010 03:38 AM
DIY Boombox happyb Multi-Way 4 27th March 2008 08:30 AM
The boombox project A3rd.Zero Everything Else 13 12th May 2004 08:15 PM
My boombox on.. tubes. :) igormak Tubes / Valves 4 11th November 2003 10:52 AM
Copyright 1999-2017 diyAudio
