Go Back   Home > Forums > Amplifiers > Class D
Old 20th March 2011, 10:52 PM   #11
Saturnus's Avatar
First rule of a good boombox build. Don't ever use anything that is meant for car audio. Ever.
Oh, and since you're nearing the Boominator dimensions anyways, why not just build that?
Old 20th March 2011, 11:57 PM   #12
Because i already got 4 6x9 speakers i want to use.
I would rather build the boominator but it'll cost 70€ more.
And i know, it feels silly to choose the amp9 instead of the amp6, but heres why:
I'm mainly planning on using it just some hours at night, not using it as a festival stereo.
Also why i choose to have 2x 12v 18Ah batteries
And saturnus, how does the magnet-magnet construction work?
How did you put together the magnets?
I really dont have a clue how you did that
Old 21st March 2011, 05:05 PM   #13
Please someone reply how the magnet-magnet construction works, need an awnser within 2 days.
Im going to start building the box on wednesday.
And i was thinking of a tone control :P
I can buy this for 10€, what du u guys think?
http://www.electrokit.se/download/k155.pdf
Btw, i plug it in between the amp and my smartphone and not between the amp and the speakers right?
Old 21st March 2011, 05:42 PM   #14
picowallspeaker's Avatar
there are many magnet-magnet configurations , in which speakers can be wired in phase or out of phase . I prefer the push-pull configuration ,because
the size of the box remains the same as a single woofer . They can be mounted nose to nail , or back to back . Since yours is a very large box , I suggest to try the design I posted : the back of the woofers share the same chamber ,they are wired out of phase , and the other chamber is vented (hole
or duct ) .
Old 21st March 2011, 05:44 PM   #15
Forgot the attachment !!
Old 21st March 2011, 06:08 PM   #16
or duct ) .
Oh, that changes everything :S
Right now i have made everything so the magnets meet each other inside the box (like the boominator),
if i will do this type i will have to make the boombox thinner but longer, about 1m long.
And if its thinner, the batteries wont fit as planned.
Is it possible to do it like the boominator thingy?
And it's not really a woofer, it's a coaxial speaker, so wouldn't the tweeter and the mid sound get reduced when using the vent idea? or am i wrong?
Old 21st March 2011, 06:18 PM   #17
Saturnus's Avatar
Wiring the speakers out of phase will also mean that there would be next to no bass at all. Probably not a good thing.
You also get none of the benefits of mount the magnets against eachother.
Old 21st March 2011, 06:42 PM   #18
No ,you 're right , as I didn't mention that you should extirpate those protruding things out of the cone .
Old 21st March 2011, 07:19 PM   #19
Waaaaiiiitttt, so you mean i can just pull out the mid and the tweeter from the coaxial? XD
So the magnet-magnet thing is just a waste of time, you just meant i should have the same woofer in the same room to get extra dB?
Now i am reaaaalllly confused >.<
Old 21st March 2011, 07:50 PM   #20
Saturnus's Avatar
No one said life was supposed to be easy
Cal's little boombox Cal Weldon Multi-Way 33 3rd December 2010 07:36 PM
Boombox in a car ashhegde Car Audio 2 11th June 2010 03:38 AM
DIY Boombox happyb Multi-Way 4 27th March 2008 08:30 AM
The boombox project A3rd.Zero Everything Else 13 12th May 2004 08:15 PM
My boombox on.. tubes. :) igormak Tubes / Valves 4 11th November 2003 10:52 AM
Copyright ©1999-2013 diyAudio
