| Class D Switching Power Amplifiers and Power D/A conversion |
#81 |
along with the signal restoration into rectangular waveform i will lose the dead time => more cross condution?
#82 | |
Do waveforms improve with the new transistor set?
I use to feel like the small child in The Emperor's New Clothes tale
#83 |
Accounting for faster gate rise time, yes, the total propagation delay is reduced and so is time between turn-off and turn-on. Buy increasing peak gate voltage you also increase the turn-off charge to be yanked out of the gate, which can also add to undesirable overlap. This might not be the entire reason switching frequency doubled, but it is probably a major factor. I'm not certain but I don't think the differential/level shift transistor changes you made would have that much of an effect. They'd just be easier to cool. You could always put the MPS transistors back and see.
#84 |
hi B.I.G did your last schema work at +/-90vlts ? is this approach of discreet class d clear as the ucd one?
#85 |
#86 |
any feedback?
| Collection of Class B topologies <100mA Idle and Sound closest by Class A | tiefbassuebertr | Solid State | 36 | 30th December 2011 06:34 PM |
| Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? | tiefbassuebertr | Solid State | 18 | 14th August 2011 10:31 AM |
| gzpa 1.8000d | margarit2001 | Car Audio | 1 | 17th March 2011 10:07 PM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
| How about a round-up of Class A kit power amps, or collectable vintage class A? | Brisso57 | Solid State | 4 | 14th February 2007 10:30 AM |
| Page generated in 0.08365 seconds (68.57% PHP - 31.43% MySQL) with 11 queries |
