| Class D Switching Power Amplifiers and Power D/A conversion |
Hi All
I'm currently in the process of designing a small amp based on a TI TPA3106. I'd like to have the output filter designed so that it will run 4, 6 and 8 ohm loads satisfactorily, without excessive peaking / THD implications (as little as possible anyway) I have read through this: http://focus.ti.com/lit/an/sloa119a/sloa119a.pdf and it seems as though the tables on pages 11 and 12 show 15-20 uH with 1.5-2 uF would be a reasonable place to start. I'm hoping that somebody can offer some suggestions on the values to use? Given that I don't have the equipment to measure the actual results, could anybody recommend a suitable software package to simulate the filter design and implications? Lastly, I see sure electronics put a 470uF coupling electrolytic after the filter on their TPA3123 board: here (page 15) (they use a 33uH / 1.47uF combination). What is the benefit to doing this and how would you guess they justified the filter selection? Many thanks Oli Last edited by Oil; 6th March 2011 at 05:46 PM. |
#2 |
The Sure TPA3123 board uses 470uF caps on the output to block the DC bias since it is a single-ended design running off a single supply. The TPA3106 runs BTL so these caps are not needed.
Here is an online filter calculator page you can mess around with.... Filter Design and Analysis On my TPA3106D1 boards I use 15uH + 1uF. I haven't measured the response, but it sounds fine to my ears running 4-8R loads.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#3 |
Just make sure the inductor will take the current for the 4 ohm setup OK.
My class d amp uses 22uh and 470nf and runs into 4 ohms very well.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#4 |
You can design for a nominal impedance of 4 ohms and use a Zobel network to minimize impedance mismatches. If you design the output filter for an Fco of around 1/5 the switching frequency (typically around 250KHz for the TI TPAxxx chips), you can pretty much get away with using LC values for a 4 ohm load and not have an audible HF peak when attaching 8 ohm loads.
| Amplifier Design for Fractional Ohm Loads | SlunkBoy | Solid State | 3 | 9th February 2010 07:01 PM |
| Driving Low Impedance Loads | weinstro | Solid State | 14 | 8th May 2005 09:53 PM |
| LC filter design | demons_wing | Solid State | 5 | 2nd July 2004 03:06 AM |
| Gainclone driving inductive loads | diyman | Chip Amps | 1 | 12th April 2004 09:53 AM |
| Zen driving high impedance loads | supa-roo | Pass Labs | 2 | 18th April 2003 07:23 PM |
| Page generated in 0.10038 seconds (75.77% PHP - 24.23% MySQL) with 10 queries |
