Go Back   Home > Forums > Amplifiers > Class D
Old 4th March 2011, 12:49 AM   #1
Smile Increasing efficiency through output inductor selection
Hi all,
this should hopefully be a nice basic question for many on here, fingers crossed!
It seems to me that many of the idle losses within ClassD designs are in the output inductors (as confirmed in the TAS5630 datasheet). I intend to modify the Class D TI-600 ( Class D Audio TI-600 Amplifier - Class D Audio Amplifiers - PRODUCTS ) in the output inductor stage to achieve a lower idle current.
What should I be looking for in an inductor to replace their stock inductors? Is it even possible? According to several online sources, 90% of the hear loss is through the wires rather than the core. However, I have the feeling it isnt quite as simple as just changing to a lower resistance inductor (while keeping the audio quality top notch)
If anyone could give me any pointers then that would be greatly appreciated.
I have been using this source http://www.inductors.ru/pdf/doc486_inductorlosses.pdf so far but dont seem to be able to get any further
Many thanks in advance!
Old 4th March 2011, 12:54 AM   #2
ps. the TAS5630 datasheet http://focus.ti.com/lit/ds/sles220b/sles220b.pdf
specifies output filter inductor values to be 7 min, 10 nominal in BTL
Old 4th March 2011, 01:09 AM   #3
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
The Pacr term in that link is the one to watch - its a function of skin effect. Skin effect means the current flows only at the surface of the conductor as frequency rises - this leads to greater losses at higher frequency. If the coil is only a single layer one, this will be dominant. It can be mitigated by using Litz wire to increase the surface area. Going simply for a lower DC resistance inductor will be very misleading in respect of losses if its only wound with thicker wire, rather than multiple thin wires.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 4th March 2011, 08:47 AM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Main sources of losses to consider:
Core losses in output inductor due to magnetic flux excursion.
Straight I^2*R losses in magnet wire.
Skin effect losses in magnet wire just due to the moderately high di/dt of ripple current.
Eddy current losses in magnet wire due to magnetic flux leaking the gap (only in gapped ferrites).
Possoble losses in switching stage due to overlap.
Losses due to hard switching and d-s capacitance of the own output MOSFET.
Losses in snubbers.
Proper dead time, gate resistors, output inductance and snubber value selection can achieve resonant operation and very low idle losses on the output stage, leaving only inductor losses to worry about.
TAS5630 output stage is probably optimized for the recommended inductor and snubber values. Integrated class D chips give little or no chances for tweaking idle losses.
The inductors in the picture look like gapped ferrite toroids. Do they get warm when the amplifier is idle? Winding your own toroids with -2 material (Micrometals) may be an alternative.
I use to feel like the small child in The Emperor's New Clothes tale
Old 4th March 2011, 05:24 PM   #5
Pafi is offline Pafi  Hungary
Not only in gapped ferrites! Even in a perfect toroidal choke the flux density is not zero between the wires and the core. On the surface of the core it drops to B/mu_relative and it decreases gradually till the outer surface of wires. While the low core loss type of powder cores have small permeability, this effect is not negligible in ClassD audio.
The most efficient "trick" to achieve low idle loss is BD modulation and combined common+differential mode choke. Ideal core material is ferrite (gapped), ideal wire is litz.
But be careful, because common+diff mode filter choke has magnetic leakage!
Old 4th March 2011, 05:56 PM   #6
The copper loss and core loss should be roughly equal to keep sum the lowest.
In the particular case of this amp, with only 7 turns on a core I guess the core loss wont be insignificant. Somewhat lower AL (bigger/more air gap) could be better, if material can be the same.
Old 4th March 2011, 07:23 PM   #7
AP2 is offline AP2  Italy
litz wire is designed only to facilitate the high-current windings. poor performance compared to solid wire in the toroid.
capacity ser-par on the winding should be zero. but this is not possible, then better segmented with a stiff wire wrapped space.
Another problem is the section of the wire. I often see the sections about 1mm. this is wrong and can not be calculated for the current only.
What hinders the development of new ideas,... it's just the theory.
Old 4th March 2011, 07:38 PM   #8
megajocke's Avatar
And what happens for thick wires is basically that the HF AC current flows in a single skin-depth deep layer, but only on the part of the wire facing the core. AC resistance is thus about twice as high as would be predicted if only considering skin effect.
If you have more than one layer of winding losses go south quickly...
The bewitching snivvie is dulcet paragon.
Old 4th March 2011, 08:28 PM   #9
nigelwright7557's Avatar
I started off using power inductors but they got red hot 120 degrees C !
Someone recommended a t106-2 core and I would my own and the coil now doesnt even get warm.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 4th March 2011, 10:27 PM   #10
Be careful! Skin depth is only 0.1 mm at 400 kHz!
Increasing output when frequency rises WrineX Planars & Exotics 2 14th February 2011 09:20 AM
Increasing inductor impedance. Tor M Multi-Way 2 2nd April 2005 07:54 PM
increasing current output xplod1236 Solid State 7 27th March 2004 06:24 AM
Source for output air cor output inductor?? sam9 Solid State 7 19th January 2004 02:25 AM
Increasing output channels of preamp. hugobross Solid State 19 6th February 2002 04:13 PM
Page generated in 0.11643 seconds (81.08% PHP - 18.92% MySQL) with 10 queries
