Go Back   Home > Forums > Amplifiers > Class D
Old 3rd March 2011, 06:29 PM   #1
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default NCDX heatsink..
I'm curious about this Class 'D' module.....how, and or where is there a heatsink...applied to this module???
And just how are these D mods?
These guys have this package deal but there are two different values for B+/-................A 42V & a 40 VDC...........40-0-40 or a 42-0-42.
Antek makes a 42-0-42, but not a high enough current.but the 40-0-40..I would go for the 1000W version...to be conservative. Couldn't one run a ribbon cable to a chassis faceplate as the module will be horizontal?......for the diagnostic display...
thoughts???????
__________________________________________________ ____Rick...............
Old 3rd March 2011, 07:29 PM   #2
isnt that the heatsink on the underside?
class D doesnt need much heatsinking. Just look at the peavy IPR series which runs at 2k without a sink :O
Old 4th March 2011, 01:49 AM   #3
theAnonymous1's Avatar
The aluminum block visible on the underside is meant to be either connected to a larger heatsink or connected to the chassis acting as a heatsink. I don't think the block itself can dissipate all the heat generated at full output power.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 4th March 2011, 01:54 AM   #4
That block is definitely just an interface part to make heatsinking easier. It's just a conductor, not a sink. Whatever you do should probably not allow that block to get warmer than say 50C.
Old 4th March 2011, 02:01 AM   #5
Since it is entirely likely that someone might try to stick that onto something like a thin piece of sheet, it also sets up a sizeable minimum thermal mass, which minimizes thermal shock.
Old 4th March 2011, 06:51 AM   #6
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
also you don't really need displays... have open case for few day to get over it, or put plexiglass or something for top side
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
New NCDX(i) module from Lars Clausen MrForce Class D 64 10th March 2010 08:21 PM
Which heatsink? wxn Chip Amps 2 10th April 2005 01:43 PM
8 inch wide heatsink 11 inch wide heatsink barrredboss Heatsink USA 13 13th July 2004 06:30 PM
Heatsink Chad Solid State 4 30th August 2001 06:50 PM
Page generated in 0.08449 seconds (69.59% PHP - 30.41% MySQL) with 11 queries
