Help in Class D amplifier designing
Old 7th March 2011, 06:03 AM   #11
dileepkella85 is offline dileepkella85  Singapore
ChocoHolic, I am using IN4148 diodes, what should be the values of C20 and C21 capacitors for charge pump which may provide enough current to maintain bias voltage.
Yes, you are right that voltage across 270 ohms resistors is PWM with DC component of 12V.
my problem is not solved yet, with varying the values of capacitors C20 and C21, I am not getting the rectangular wave at lead 2 of PMOSFET IC.
Old 7th March 2011, 07:22 AM   #12
what can other possible ways to drive these MOSFETs, with any driving IC.
Plz help!
Old 7th March 2011, 07:04 PM   #13
ChocoHolic is offline ChocoHolic  Germany
This way to drive the Fets is the most simple way I am aware of.
All other methods offer even more chances for headache.
Please note, the solutions with driver ICs are usually designed for two N-chanel MosFets.
In order to find the problem of your circuit, please post screen shots of the signals in your breadboard.
How does the 12V rail look?
How do the PWM signal look at the output of the 555?
How do the PWM signals look at the outputs of the inverter IC?
How do the PWM signals look at the bases of the bipolar stages?
How do the PWM signals look at the emitters of the bipolar stages?
How do the PWM signals look at the gates of the MosFets?
If it is to much action to send screen shots of all these nodes, simply follow
the signals according above list and send screen shots of the last point which is looking right and the first point which is looking wrong.
Old 7th March 2011, 07:14 PM   #14
If C20 and C21 are 1uF then the resulting time constant with the 270 Ohms is 270us. At 40kHz and 50% duty cycle the ON time is 12.5us.
Consequently the 1uF is easily large enough to provide a rectangle with almost flat top.
Old 7th March 2011, 07:59 PM   #15
...you are saying, that you are not getting the rectangle at pin2.
Do you get the opposite rectangle at pin 4?
How do both signals look?
Old 8th March 2011, 04:51 AM   #16
Hi ChocoHolic,
Thank you very much for your responses and help. I was getting the screen shots for you to better understand the happenings over here, meanwhile I changed the value of capacitor C20 and C21 and luckily I got output at the output of MOSFETs.
Actually in this circuit value of C21 and C20 is very crucial, the change in these values causes to burn Pmosfet IC. Currently I have used 0.22uF.
If we compare the power level of PCB board (already made) and breadboard there is big difference, the breadboard one has low sound level, what can be the causes and how can I improve that, varying the value of capacitor does not improve the sound level but causes to burn the MOSFET IC.
Thank you very much for your co-operation and also my thanks to diyadudio.com.
Dileep
Old 8th March 2011, 08:56 PM   #17
No doubt, the value of C20 and C21 can be critical.
If it is to small - it will be discharged to fast by the 270 Ohms and gate drive will not be sufficient. I would not directly expect defects, but the MosFets might turn OFF to early and in a slowish lossy manner.
If you go to larger values for C20 and 21, then the start up sequence becomes more critical due to cross conduction effects.
Especially if you have a strong power supply this may lead to defects.
Does this fit to your findings?
Low output power:
Multiple issues could be the reason, here the first three which are coming to my mind:
1)If you examine the 12V with the scope: Is the 12V stable under full load?
2)Do the outputs of the bridge deliver proper PWM with full 12V under full load?
3)Do the both outputs of the bridge always switch nicely inverted rectangles, when checking the switching during max output? Or do the MosFets, which should have the long ON time turn OFF to early?
Old 10th March 2011, 04:50 AM   #18
I do have lab power supply, is this strong power supply?
Low output power:
I observed that it has impulses when it is under load.
and definitely the output is not perfect rectangular pulses with 12Volt.
Not nicely there is impulse at one edge may be due to power supply noise and on and off times looks me fine.
How to remove noise now from Power Supply..... with capacitor?
In the circuit diagram if you look at, there are capacitors which are connected between source and ground to remove noise what should be the value of those capacitors?
Old 10th March 2011, 08:58 AM   #19
Can you forward some material to read on this regarding MOSFETs operation or any book to read?
Thank you very much.
Dileep
Old 10th March 2011, 06:41 PM   #20
Lab Supply:
Some can be very strong, some not.
But usually they offer an adjustable current limitation.
A reasonable setting for power experiments of this amp would be 1.5A.
During normal experimentation it should be sufficient to adjust the current limitation to 0.5A.
Supply caps:
The large 2200uF is large enough, no need to increase.
The small ones should be in the range 0.47uF...1uF, preferably ceramic types placed close at the MosFet and short wires/small loops.
It is not only about the components. In switch mode systems (like class D) also wire lengths and geometric size of the current paths/loops do influence the behavior.
...observed impulses on the supply....
...not perfect rectangular pulses at the MosFets....:
There is no way to analyze the issues of your breadboard without
screen shots plus clear info where the probes had been connected plus scaling information plus load situation.
Analyzing short comings of the bread board itself would need
multiple pictures of the breadboard, from different views and distances.
Material to read:
I do not have a special recommendation for you. There is no book, which teaches us all key topics. It is a long path of summing together fragments. But the WEB is full of information.
Start your search with basics of MosFets or similar.
..or how to use MosFets ... and so on...
Do not just focus on MosFets. Basically one has to understand all the
fundamentals of electronics - which is nothing that can be learned within few days.
Class D in fact requires more than just the fundamentals.
Most people who really know about class D, had to learn electronics theory for multiple years and have practical experience of multiple thousands of hours on the work bench or even multiple 10k hours.
I don't care if somebody went to the university or not, university is just helpful to speed up learning the theoretic part and to have a respectable paper in hand...
But in any case it is a long path to learn electronics in a proper manner.
Experience is proportional to the number of devices you killed by accident + the number of components from which you made reliably working circuits.
Experience which you gain on own designs is boosting you more than experience with copied designs. Unfortunately for own designs everyone has to start with micro baby steps.
Help in Class D amplifier designingHide this!Advertise here!
Help with designing differential amplifier krish2487 Solid State 12 24th February 2009 03:07 AM
help me in designing an amplifier nightcatz Chip Amps 4 22nd June 2007 07:57 AM
Designing power supply for class D amp darw82 Power Supplies 1 3rd December 2006 08:24 AM
Copyright ©1999-2017 diyAudio
