Go Back   Home > Forums > Amplifiers > Class D
Old 23rd February 2011, 08:14 AM   #1
Send a message via MSN to egberttheone
Default General discussion LC-filter class-D
I'm a bit confused about the output filter, after reading a lot of posts here and some googling did not find my answers.
I want to use the classic common mode filter design.
After having put the recommended filter (STA516B) in LTSpice (22u coils) it showed quite a phase-shift about 35 degrees @ 20khz.
To lower the phase shift you need to lower inductance but doing so will also change the corner frequency.
Lowering the coil tot 4.7u and capacitors to 10n gives only 9 degrees phase-shift @ 20khz.
But the attenuation for the carrier (384khz) frequency is not high enough.
The original filter gives about -6db @ 384khz and the 4.7u coils gives about 9db @ 384khz
This is all simulated with a 100v source and a resistive 8ohms load.
I'm a bit confused, which is the way to go?
Is it worth the effort to lower the inductance and get less phase-shift or is this not hear-able?
In the picture you see a snubber network on the left and @ the right a zobler network.
Old 23rd February 2011, 10:27 AM   #2
Pafi is offline Pafi  Hungary
This is true.
You can decrease phase shift (and load-dependance, and distortion) with post-filter feedback, but it can cause some other problems, so i don't recommend it unconditionally.
Old 23rd February 2011, 02:47 PM   #3
Originally Posted by Pafi View Post
This is true.
Thank you for your reply, so i don't have to worry about the phase shift.
What about the zobel network (please ignore the values in the picture i have to calculate those)?
It is not included in the example of the STA516B data sheet, but is it a wise thing to add? Can it cause harmonic distortion adding this network?
Old 23rd February 2011, 05:32 PM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
You are a victim of hi-end misunderstandings about audio.
What you have to analyze is group delay, the amount of delay involved (that will not be substantial actually) and it's uniformity across the audio band. An uniform delay is not a problem either.
Think about the phase shifts and group delay discontinuities from speakers...
One 20Khz wavelength measures 17mm while propagating through air. Just having one speaker 8mm further from you than the other will result in 180º phase shift from one channel to another in that frequency range. Fortunately our ears don't care about phase at such high frequencies
I use to feel like the small child in The Emperor's New Clothes tale
Class-D Amp LC-Filter: Coil heating klausix Class D 52 26th February 2011 05:59 PM
Output LC filter help krish2487 Power Supplies 2 21st November 2009 12:25 AM
General power amplifier stability discussion (using Spice) cbdb Solid State 38 2nd May 2009 09:50 PM
Class D - LC output filter - C ripple current Skeebopstop Class D 8 26th February 2009 05:08 AM
How crucial C in LC filter? rider Analogue Source 0 8th July 2004 09:05 AM
Page generated in 0.08668 seconds (71.70% PHP - 28.30% MySQL) with 11 queries
