New Puter speakers
New Puter speakers
Old 19th February 2011, 01:39 AM   #1
hybridfiat is offline hybridfiat  Australia
Default New Puter speakers
White American oak. Same vol as the original IBM Aptiva speakers that came with our very first puter in 1997. The amp was nice. Based on a Philips chip it sounded real good in combination with these drivers. One is 4" the other 1". Big magnets, sheilded and matched well to the task.
The little amp finally gave up and I couldnt be bothered trying to fix it. So away with the plastic enclosures and in with the new. An Arjen 15w/channel amp and real wood.
Good mid and high range but no bass to speak of. I connected the amp to my floorstanders and they didnt sound much better so I connected the speakers to my LM3886 amp and sweet sounds emanated. I havnt got the room inside the enclosures for an LM amp nor the inclination to build another so I will either put up with the lack of bass (They are workplace speakers after all) or modify the amp. Bigger caps maybe?
Anyway they sound better than the internal speaker of the hp computer and cost next to nothing. $14 all up.
Entia non sunt multiplicanda praeter neccissitatem
Old 21st February 2011, 09:51 PM   #2
purplepeople is offline purplepeople  Canada
purplepeople's Avatar
Baffle step compensation? If not in circuit, can be approximated with the PC graphic equalizer.
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 21st February 2011, 09:55 PM   #3
Yeh, you are right. Ive played with the EQ and got a better sound.
Im getting a bit of distortion on some tracks and Im not sure if it is my speakers, the EQ changes or the amp. I think the EQ at this point.
Old 21st February 2011, 10:03 PM   #4
I'm just guessing but based on the photo, I'd say you need BSC at between 1-2kHz. Set your EQ flat to zero until about 1000 Hz, then -3dB at 1500 Hz, then -6dB for all bands from 2kHz and up. Notice it's all cut, no boost. Avoiding boost is the quickest way to avoid distortion on any system you aren't sure of and especially with on-board PC audio.
:)ensen.
Old 21st February 2011, 10:17 PM   #5
That sounds better Thanks
New Puter speakersHide this!Advertise here!
Studio monitor speakers as Hi Fi speakers? MRod Multi-Way 2 27th March 2009 05:07 AM
New audio system for my 'puter ebogga Multi-Way 19 24th January 2009 03:44 PM
Built differences between Guitar Speakers and PA Speakers? agadis PA Systems 7 24th September 2007 08:22 AM
FS : Studio One Pi Speakers aka Fred's EZ speakers Cacophonix Swap Meet 6 10th September 2007 10:56 PM
DJ Speakers.... Worse than PC Speakers Mikett Multi-Way 34 14th January 2004 05:06 PM
Copyright ©1999-2017 diyAudio
