Go Back   Home > Forums > Amplifiers > Class D
Old 18th February 2011, 05:05 AM   #1
surZ90 is offline surZ90  Indonesia
Default does anyone know new methods of modulation in class d audio amplifier
Hi all...
I'm new in class d audio amplifier...
I'm looking for a new modulation method in class d audio amplifier for my final project ...
does anyone can help me?
thanks
Old 18th February 2011, 09:15 AM   #2
Send a message via Yahoo to Th3 uN1Qu3
Don't you think that if a new method was found, we would be out marketing it first instead of giving it for free?
Build something using one of the current methods first, get accustomed to it, break it in every way then fix it again. Learn how every part of the circuit operates. Then worry about "new".
"Audio grade" components simply means that they failed at a more critical job.
Old 18th February 2011, 10:54 PM   #3
nigelwright7557's Avatar
Originally Posted by surZ90 View Post
Hi all...
thanks
The usual PWM method can also be adapted so it only outputs pulses when there is sound. When there is no sound there is no 50%/50% PWM output at all.
This makes for a very efficient class d. There was a video on youtube explaining it but I cant remember where it was.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 18th February 2011, 10:58 PM   #4
Found it !
He goes on to explain a filterless class d amp using a modified pulse system.
YouTube - An Overview of Class D Audio Amplifiers
Old 19th February 2011, 12:48 AM   #5
Pafi is offline Pafi  Hungary
But it's not really new. If it were human, he could have childrens. Teenagers...
Old 22nd February 2011, 06:00 AM   #6
I know some modulation methods such as self oscilating, PWM, delta sigma and sliding mode control. However, I do not really know the details, advantages and disadvantages for each method. Can anyone help me to give an idea about this?
Old 22nd February 2011, 06:15 AM   #7
Saturnus's Avatar
Isn't this the sort of things you're supposed to be reading up on when you're going to use it for a final project?
One thing you could look into is combining class D and class H.
Old 22nd February 2011, 02:29 PM   #8
fredos is offline fredos  Canada
Phase shift modulation with a 4046. Use the XOR output to drive your output stage. Work well, but this technique lose control at clipping. The frequency shift go outside the gap band of the PLL.
Old 23rd February 2011, 05:42 PM   #9
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Single cycle control: A mix of feedforward and non-linear control, calculating duty cycle for each switching period with non-linear functions (like integrators) in such a way that all the errors are corrected as they appear instead of becoming cummulative (like in every triangle wave scheme). And doing that without getting a wide range of switching frequencies as a result.
I use to feel like the small child in The Emperor's New Clothes tale
AD Vs BD Modulation in Class-D Workhorse Class D 86 12th May 2011 02:00 PM
How many modulation methods in Class D amplifier ? xuhaoz Class D 20 5th December 2006 04:15 AM
Class D Modulation Scheme pokka Class D 7 15th December 2004 07:33 PM
new class D modulation method? sfx Class D 12 6th October 2004 07:02 AM
Testing & Measurement Methods for Mobile Audio Amplifier Hi Speed Car Audio 0 20th May 2004 05:19 AM
Page generated in 0.10296 seconds (77.15% PHP - 22.85% MySQL) with 10 queries
